Author Topic: excessive front tyre ware - inner edge - bushes?  (Read 2970 times)
i260
  • Newport, South Wales
« on: 26 June 2011, 10:47:00 »
My front tyres have worn off on the inside edge completely within 5000 miles and the last pair had gone this way too but over a longer time period.
The tracking was checked when the tyres were fitted and the fitter said there was visible negative camber on the fronts and it measured at 1deg.
He pointed out that the lower n/s lower wishbone bush was showing signs of ware.
My dilemma is that I understand the pattern part replacement wishbone complete item is significantly cheaper  than the vx item but have heard the bushes arent up to much. Any comments??
Get a wishbone and chop the bush out and stick a poly item in?
Also, are there other bushes that could lead to this excessive tyre ware and would changing these make the consideration of replacing shox / springs a sensible idea??
Just trying to make sure it dont do part of it and have to repart some of the labour later.
NB - all the suspension & bushes on the front are original & 95k
edit:
looking further into this from the maintenence guides etc this does sound the likely cause.
As a moderate novice (but I have installed coilovers on a golf single handed) is attempting changing the wishbones myself advisable?
I see several options on ebay but the link below does at least have the oil filled bush.
Do I really need to get new drop links as well?
http://cgi.ebay.co.uk/WISHBONE-SUSPENSION-ARMS-SET-KIT-VAUXHALL-OMEGA-B-NEW-/330570852008?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item4cf78ee6a8
« Last Edit: 26 June 2011, 11:12:30 by i260 »
Saab 9-5 Aero 260ps
Re: excessive front tyre ware - inner edge - bushes?
« Reply #1 on: 26 June 2011, 11:37:24 »
poly bush your existing wishbones.
only do droplinks if they are knocking.
get the geometry set up properly, by someone who knows that they are doing and just just go by 'the computer'
i260
« Reply #2 on: 26 June 2011, 11:54:38 »
...and NOT just go by the computer?
Is it reasonable to take my existing wishbone off and put the poly one in and get it back on in a day / few hours?? Can it be done without taking the wishbone off??
I would love to do the poly bush route to firm things up a bit but are there any other bushes on a wishbone that would benefit from?
Saab 9-5 Aero 260ps
o-meg-a
  • south wales
  • avatar disabled meantime as its mahoosive!
« Reply #3 on: 26 June 2011, 15:49:30 »
I've heard of front polys being doe while leaving wishbone on the car.
So it is doable.
No other bushes on the wishbone are available off the shelf in poly.
Just the front ones.
Otherwise you'd have to get some made up for the back one.
Not really any benefit from that though.
As for the Geometry and NOT going by what the computer says.
Reason for that is that the "computer defined settings" are from a factory database which does not take into account the natural sagging of springs etc.
Anyone who knows what they are doing with this car will know better as to what settings will work for your car! The people at Wheels In Motion for instance.
They dont just "get it in the green" like a lot of places do.
« Reply #4 on: 26 June 2011, 15:55:54 »
excessive shoulder wear is always camber. Its what causes the camber to be wrong.
It seems Omegas generally get more camber with age, even if you replace all the suspension components. Hence I tend to get mine realigned every 12 - 18 months.
So check all bushes, replace those that need doing, and then get it geometry checked by somebody who knows what they are doing.
Rebushing can be done in a day. Mine where done in about 3hrs last week (poly front bush, rubber rear), and they were a bit of a git to get out.  You do need a press and some good drifts to do it though.
i260
« Reply #5 on: 26 June 2011, 16:42:58 »
no presses, no drifts.
Have seen the guide to cut the old front ones out - can the new ones be knocked in?
Do the rears wear as much as the fronts and can they also be done in situ?
I suppose the other option is to get a new pair of wishbones and change the fronts for poly before fitting them??
Saab 9-5 Aero 260ps
o-meg-a
  • south wales
« Reply #6 on: 26 June 2011, 16:46:53 »
Yes that is an option, an easier one.
Can be worth buying a set of cheapo wishbones (£50 a pair ish), and polybushing them first.
(another £50).
Not sure about presses and drifts,
I was under the impression they could be done on the car see, so i would think a press wouldnt be an option in that situation?
anyone else with better knowledge?
« Reply #7 on: 26 June 2011, 19:48:07 »
Are the rear bushes failed?
Either way, easier to remove the wishbones...
i260
« Reply #8 on: 26 June 2011, 20:24:09 »
no idea about the rears - do they get an easier life than the front bush?
Would have thought that after 100k they would have seen better days and benefit from replacement.
So, my thoughts are to get a half decent pattern part that will have some reasonable rear bushes and then fit poly fronts either myself or get my local indep. to pop them in for me and then just swap the wishbones over.
Is it ALL the bushes on pattern wishbones that are a little suspect or just the front?
Or do I get the cheapest pattern wishbone and get a decent rear bush and the poly fronts pushed in?
Saab 9-5 Aero 260ps
« Reply #9 on: 26 June 2011, 23:14:21 »
examine your rearward wishbone bushes by jacking the car, remove the wheel for easier acess. If any signs of splits are evident, replace the whole arm for lemforders.(you may wish to fit Polly at this stage to new wb's as it's easiest)
If ok(they will be breaked btw) fit polly while the wishbone is fitted to the car.
Rearward bush lasts longest by all accounts, but I think it's safe to say any omega with unknown bush history will need most bushes replacing.
Rubber doesn't last long enough given production stopped in June 03. Certainly all the bushes are fooked/Been or being replaced on my 03 with 68k on it.
If you plan to keep the car and want the thing to drive straight see here
http://www.omegaowners.com/forum/YaBB.pl?num=1283124735
IMO pattern wb's are a gamble. If they last, great. But nobody knows which pattern ones last and which don't. Some members have good results, some not, even from the same supplier.
If it was me, fit lemforder, torque with wheels loaded, set it up and go from there. If the fronts fail, then fit Polly. Up to you though.
Hth
« Last Edit: 26 June 2011, 23:16:14 by chrisgixer »
i260
« Reply #10 on: 26 June 2011, 23:30:00 »
Thanks for that.
The history is known - my dad had the car from 6 months old and they have never been done! Entire new wishbones methinks!
(nearly there!!)
« Last Edit: 26 June 2011, 23:32:40 by i260 »
Saab 9-5 Aero 260ps
    • 530D M Sport, 330i Coupe
« Reply #11 on: 26 June 2011, 23:35:24 »
Personally i'd go with Chris's advice above, pop some Lemforder's on then when the front bushes fail again in the future just fit some poly bushes in the fronts.  :y
Oh and if your wishbones are originals someone on here might take them off your hands and get them rebushed.  :y
i260
« Reply #12 on: 26 June 2011, 23:43:00 »
Eurocarparts for Lemforders then!
ooo hadnt though about the appeal of s/h oem wishbones!
mmmmmmmmm
T H A N K S    E V E R Y B O D Y    F O R    A L L    Y O U R    H E L P    A N D    P A T I E N C E
 :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y
Saab 9-5 Aero 260ps
mrgreen
  • Salzburg/austria
    • 2000 2.2 petrol estate
« Reply #13 on: 27 June 2011, 00:44:33 »
I think my wishbones are on the way out too it has 100miles on it now it seems about right, i haven't checked/noticed tyrewear but it tramlines sometimes like a pig which is probably the rear bush more than the front, i've had poly bushes here for 4 months now waiting to go in but my to do list never seems to get smaller and these are always on the losing end of it!!
Warning: Dates in Calendar are closer than they appear.
« Reply #14 on: 27 June 2011, 00:51:15 »
Level sensor holes aside, I'd give all Germanparts a bell for a price at least. Euro car parts may be ok, but I have concerns about shelf life and matching pairs. They summon odd parts from where ever from with in the group, so could end up with one that's been on the shelf for months and another fairly new.
Where as Allgerman order direct from ZF I believe. Which I guess/hope would mean a more matching "newer" new set.
Maybe?
Page created in 0.024 seconds with 16 queries.
