Airbag light on!
Started by Kate, 27 June 2011, 15:45:37
Kate
Hi everyone!
My airbag light has come on and as usual I haven't got a clue what to do about it.
I've got an "My Naff Code Reader" diagnostic interface but I have never used it before.
Can anyone give me some advice please?
Many thanks!! :y
Hiya Kate...well get you though it....
ok.....Is the "My Naff Code Reader" software installed and working?
If not....what operating system and version is your laptop running?
Kate
QuoteHiya Kate...well get you though it....
I haven't installed any software yet as I had to sell my laptop to buy the mig! ;D ;D ;D
My daughter has a laptop with windows 7 on it though. Not sure which version it is.
Ok....Ill send you a PM.
Kate
"My Naff Code Reader" - KW82 Communication Window> 1998 (W)|Omega-B|Body|Airbag SAB6
KW82 protocol initialized.
ECU ID= DC,90565938,S0052655,440602,1398,
Total number of fault codes: 1
00081 - Passenger Side Airbag Sensor Communication Circuit Malfunction
"My Naff Code Reader" 100219a - PC based diagnostic tool
Date and time>,28/06/2011. 17:5600
Workshop information:
hkj
Selected model>,1998 (W),Omega-B,Body,Airbag SAB6
Control Unit:
Measuring blocks information:
System Voltage,11.44 V
System Voltage Status,Okay
Airbag Configuration,Side Airbags
Pretensioner Configuration,Driver&Passenger
Driver Airbag Squib Circuit Resistance,3.03 Ohm
Passenger Airbag Squib Circuit Resistance,2.15 Ohm
Driver Pretensioner Circuit Resistance,2.33 Ohm
Passenger Pretensioner Circuit Resistance,2.25 Ohm
Driver Side Airbag Squib Circuit Resistance,2.80 Ohm
Driver SAS Message Status (Side Airbag Sensor),Okay
Passenger Side Airbag Squib Circuit Resistance,2.56 Ohm
Passenger SAS Message Status (Side Airbag Sensor),Okay
Reset Passenger Side Airbag After Activation (DTC69),Inactive
Reset Driver Side Airbag After Activation (DTC68),Inactive
Reset Pretensioning Devices After Activation (DTC67),Inactive
Driver SAS Initialisation Status (Side Airbag Sensor),Okay
Driver SAS Communication Error (Side Airbag Sensor),None
Passenger SAS Initialisation Status (Side Airbag Sensor),Okay
Passenger SAS Communication Error (Side Airbag Sensor),None
DTC set since,0
Right....would it let you clear DTC codes?
If so, nothing to worry about.
If not, 1st thing I would do is unplug the multiplug that goes into the door, then reseat it, then try again to clear codes with "My Naff Code Reader".
Im sure that refers to the sensor in the door.
Has the door card been off lately
