Author Topic: HBV Issue  (Read 1893 times)
GarciasMuffin
HBV Issue
« on: 06 July 2011, 10:12:42 »
Morning all,
I have an omega 2.2 DTI Y reg.
I have a couple of questions.
1) In the threads I have read, the HBV is always mentioned as being at the back of the engine.
The part that I believe is the HBV on mine is at the front near the rad. It also has only two ports not three, but looks identical in all other ways to the HBV pics I have seen.
Is this also an HBV but for whatever reason on my model it is in a different place on the car ?
2) Mine is leaking, but what I think I see when I take it out the car, is that it looks like (I can't be sure) there is a small square hole where water could come out that was made intentionally and it could be coming out of this.
Am I incorrect and the part should never eject water at all, or is this some kind of safety mechanism that releases water when something else is wrong on the car ?
As a side note, I couldn't get the stupid clips off the thing so cut the hoses off as near to the port ends as poss and replaced clips with jubilee clips, now only takes 5 mins to get off and on again.
Many thanks in advance for any help.
GaryBC
  • Egham, Surrey
Re: HBV Issue
« Reply #1 on: 06 July 2011, 10:46:08 »
I'd love to be of more help but I only know my engine - the 2.5V6.
But what I can say is that no, it shouldn't leak! And, given the item you've found has only two ports, one wonders if it is indeed an HBV. (Not sure how it could bypass - the "B" in "HBV" - the heater matrix if it has no third port to shunt the hot water to.)
And as for upgrading to proper jubilee clips; I do that every time too!!
Someone here will help you more. It's a brilliant site populated by helpful and friendly people.
GarciasMuffin
Re: HBV Issue
« Reply #2 on: 06 July 2011, 10:48:51 »
Just remembered something else I was going to ask.
The fans were not kicking in so the car kept going into recovery mode when the needle went of the dial.
I've managed to fix this now (dirty connections) but whilst I was trying to figure out how to fix it, I put the heater up to HI (yep, even on the boling hot days we had with all windows down  :) .
This went on for about a week until I fixed the fans.
Is it doing this that caused the leak in the HBV ?
GarciasMuffin
Re: HBV Issue
« Reply #3 on: 06 July 2011, 10:55:23 »
Thanks GaryBC, much appreciated mate.
I'm 99% sure it is an HBV but for whatever reason a different type of one ???
I've cleaned it up and can see two part numbers on it now. 90566947 and 90566948. When I type these into Google it still only shows the three port one, not two, WTF ???. As I said, this is the only difference in appearance all the rest of the part is identical.
Is mine a limited edition with only two port HBV, I've bought a classic car  ;)
GaryBC
  • Egham, Surrey
Re: HBV Issue
« Reply #4 on: 06 July 2011, 12:08:13 »
'Fraid the best I can offer is to echo your exclamation!! Now, if you'd had a 2.5V6 petrol.......!
As I say, someone here'll be able to help.
Gaz
fiend61
  • york
  • each to their own
    • 2.5cdx 3.0mv6 3.2vec c
Re: HBV Issue
« Reply #5 on: 06 July 2011, 12:38:03 »
hmm i thought that all omegas had the hbv at the back of engine (lefthand side as looking in enginebay) might be wrong but thinking about it how can it be a heater bypass valve with only 2 ports  :-/
have a look at the back left of engine for one with 3 ports that will be your hbv  :y and sorry i dont know what the one you are talking about is  :-/
GarciasMuffin
Re: HBV Issue
« Reply #6 on: 06 July 2011, 12:38:31 »
Ok, I believe this part is called a heater CONTROL valve, not heater BYPASS valve. This makes sense after what Andy said about how is it bypassing.
I have ordered the part and fortunately for me the guy at my local Vauxhall dealership had a picture of the component so I could verify that the part was the correct two port one.
Hi fiend, I see no three port valve at the rear of the engine.I don't know whether I have a control valve instead of a bypass valve or both, but as I say, they look identical apart from the number of ports.
Thanks for your help mate.
« Last Edit: 06 July 2011, 12:40:42 by GarciasMuffin »
fiend61
  • york
  • each to their own
Re: HBV Issue
« Reply #7 on: 06 July 2011, 12:46:59 »
have a good look and you might eventually find your 2 missing pots aswell  ;D ;D ;D
GaryBC
  • Egham, Surrey
Re: HBV Issue
« Reply #8 on: 06 July 2011, 12:49:32 »
I know mine is the 2.5V6 petrol, but try this.
Find where in the bulkhead the heater pipes come through from the cabin into the engine bay. (Above the driver's feet?).
Follow them and one should (I think) connect directly to the HBV.
There are loads of pics here in the 'How To' section. Does one of them not help?
GarciasMuffin
Re: HBV Issue
« Reply #9 on: 06 July 2011, 13:54:47 »
I'm not trying to change the HBV mate. I'm changing the HCV.
I posted initially because the two things were almost identical in look so I assumed (incorrectly) I had a two port version of the HBV. In fact typing the part numbers on the HCV brings up only images of the HBV which makes the whole thing so bloody confusing.
I can clearly see now that the HBV is located at the back of the engine as opposed to my part HCV which is 6 inches down and to the left of the alternator and a bloody sight easier to replace  :)
Now I know its name I have managed to find an image of it. If you look at the image of it here, you will see why somebody with no experience like myself could easily get confused. In fact on another thread about the HBV a guy called Pete states that his HBV is at the front of the engine so I am pretty sure he also got confused into thinking that he simply had a different version of the HBV.
I'm just surprised nobody else seems to have this component on their Omega. Maybe it was only on certain models ??
http://www.alibaba.com/product-gs/465028451/Heater_Control_Valve_BL_03_1041.html
« Last Edit: 06 July 2011, 14:12:16 by GarciasMuffin »
Re: HBV Issue
« Reply #10 on: 06 July 2011, 14:18:15 »
We are all talking about 1 and the same thing.
there are different versions for...
All petrols
S6 Diesel
2.2 Diesel
And they live in different locations.
In the UK. as far as I know, all known as Heater Bypass valve  (have invoices here with it on)
Re: HBV Issue
« Reply #11 on: 06 July 2011, 14:25:54 »
HBV is the same as HCV, and yes on the 2.2 diesel it`s at the front of the car as you say, and yes it has less ports than the petrol version
http://farm5.static.flickr.com/4115/4859561821_bb0eccfa6b.jpg
« Last Edit: 06 July 2011, 14:32:48 by RobG »
GarciasMuffin
Re: HBV Issue
« Reply #12 on: 06 July 2011, 16:43:10 »
Excellent stuff.
Looks like I fortunately have one of the easier ones to change.
Thanks for everybody's help in clearing that up for me  :)
Just have to wait till Friday for it to arrive.
