Author Topic: ac compressor replacement  (Read 2829 times)
vbelen4
« on: 06 July 2011, 14:31:15 »
Has anybody replaced the omega ac compressor and could give me some advices? I'm wondering about doing myself, but I can't find a howto...
Thanks in advance.
Re: ac compressor replacement
« Reply #1 on: 06 July 2011, 19:16:23 »
Thanks in advance.
There no howto but although it'd bloody awkward it's quite straight forward. Remove all the 'bagpipes' from the front of the engine because that the direction the compressor will be taking. It's held with five bolts, 3 at the front by the fan belt & 2 at the back of the compressor. The in/out pipe work is held to the compressor via a single bolt - I slackened this from the top using about 2' of extension bars (15mm or 16mm IIRC  :-/) After you've disconnected the single plug from the side, it should come out. I'd recommend you have the car as high up in the air as you can ....... ramps were the best I had.
vbelen4
« Reply #2 on: 07 July 2011, 15:45:33 »
I thought the compressor should be extracted with the pipes attached, as it has no room to go out...
« Reply #3 on: 07 July 2011, 21:03:11 »
the a/c pipes aren't flexible enough to remove it with them attached. :y
Matchless
  • Nottingham
    • A white van
« Reply #4 on: 07 July 2011, 23:22:33 »
As above.....long extension from above to remove the one bolt holding the pipes to the compressor.
Undo mounting bolts and bolt fixing pipe clip near front of compressor.
Ease the compressor forward and rotate one way, and then the other to clear the filler plug and connector from obstructions.
When refitting, the pipes must be in position before sliding the compressor in. Get the compressor home and fit the pipes and bolt before fitting the compressor fixing bolts.
You can just get a hand to the pipe fixing plate from underneath, reaching over the engine mount.
vbelen4
« Reply #5 on: 08 July 2011, 21:02:43 »
Weel, I'm going to resign, I can't either see the bolt that attachs the pipes to the compressor from above How can I place o-rings and so on...
I thought the comp. plus pipes were extracted together....
grijander
« Reply #6 on: 09 July 2011, 17:16:07 »
You are right, I replaced two years ago the front bearing from comp. and both, pipes and comp. came outside together, just enough to remove the bolt. And yes, replace both o-rings. Must have some pic somewhere.... ;)
« Reply #7 on: 09 July 2011, 17:18:02 »
... And yes, replace both o-rings. Must have some pic somewhere.... ;)
They're not O rings, more like a dowty seal  :-/
grijander
« Reply #8 on: 09 July 2011, 17:26:03 »
Could have a metalic rinforcement....
grijander
« Reply #9 on: 09 July 2011, 17:27:05 »
Ecco.....
vbelen4
« Reply #10 on: 12 July 2011, 06:24:21 »
Great pic really. As I see it isn't necesary to free the pipes from its connections upside...
manolo
« Reply #11 on: 13 January 2012, 12:36:24 »
also need to replace AC compressor. Repair and reseal costs 250$  :-X
where on Ebay to find good one and cheap? (I doubt the Chinese is OK)
and wath to do with oil dirty sensor (left on the picture)? leave it or repair?
