Author Topic: Where can I get a v6 water pump from...  (Read 2907 times)
GmasterT
  • Cambridge
  • does that drifting thing...
« on: 17 July 2011, 00:46:38 »
On a sunday?! Im a bit leaky and stranded in north london! I gather it doesnt involve the cambelt?
Re: Where can I get a v6 water pump from...
« Reply #1 on: 17 July 2011, 01:27:04 »
Got a used one in my shed which could get you out of trouble if your desperate. Dont suppose you could get a mate to nip up the M11 as far as Stansted in the morning ?
You might find one at a motor factors or Hellfrauds after 10am.
Youve got my number, so if your desperate for one, give me a ring. :y
« Last Edit: 17 July 2011, 08:00:13 by albitz »
MutantCav
  • Gainsborough
« Reply #2 on: 17 July 2011, 07:58:14 »
You can change the water pump without removing the cambelt...in fact although its a little trickier accessing the 3 bolts holding it on you don't even need to remove the cambelt cover
Gaffers
  • NE Hampshire/Surrey
    • Ford Ranger Wildtrak
« Reply #3 on: 17 July 2011, 08:06:16 »
Immodium usually does the trick
blackviper90210
  • Bromsgrove, West Midlands
    • 03 3.2 Elite Saloon
« Reply #4 on: 17 July 2011, 08:12:55 »
;D ;D ;D ;D ;D
AKA - Mr Bracket
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #5 on: 17 July 2011, 08:57:38 »
I'm sure that if you sit down with the local yellow pages you'll find a motor factors open. There are at least 2 around here that open on a Sunday.
Chris_H
  • E London/Essex UK
    • Jag XF Portfolio S 3.0D
« Reply #6 on: 17 July 2011, 09:30:31 »
If it's only "a bit leaky" I would get some screwtop containers of water and get myself to somewhere more favourable, topping-up as I go.
First Vauxhall - PABX Cresta; Previous, previous Vauxhall - 3.0 12v Senator CD; Previous Vauxhall Omega Elite 3.0V6 Saloon Auto
blackviper90210
AKA - Mr Bracket
jonnycool
  • Merthyr Tydfil, S. Wales
  • We shag 'em, you eat 'em
« Reply #8 on: 17 July 2011, 09:58:46 »
I thought the water pump was driven by the cambelt, and that many cambelt failures are due to the water pump bearing failing  :-/
« Reply #9 on: 17 July 2011, 10:13:32 »
V6 pump isnt cambelt driven.Failures are due to tensioner bearing/pulley collapsing. :y
noel
  • frome somerset
  • i feel the need for speed
    • 02 omega 2.6 v6 cdx auto
« Reply #10 on: 17 July 2011, 10:18:23 »
v6 water pump is driven by serpentine belt not cam belt  :y
jonnycool
« Reply #11 on: 17 July 2011, 10:35:39 »
Ah, forgive me for being such a div, but why do we change the water pump with the cambelt then, just because it is accessible at the time?
amba
  • Medway towns
    • German V6
« Reply #12 on: 17 July 2011, 10:44:10 »
Most reckon that it is good practice to replace the V6 water pump everyother cambelt/tensioner replacement.
I doudt they are that prone to failure and would almost last 100k or more miles if proper coolant regime is followed but as access is some much better with belt and cover removed for the extra £30 or so it is just peace of mind.
jonnycool
« Reply #13 on: 17 July 2011, 10:46:33 »
You learn something new every day, thanks chaps  :)
noel
  • frome somerset
« Reply #14 on: 17 July 2011, 10:46:50 »
peace of mind  :y
