Author Topic: Omega estate rear suspension  (Read 1276 times)
pmc_3
« on: 24 July 2011, 21:40:25 »
Hi guys, i've got a 2000 W plate 2.0 16v Estate. I had the MOT on saturday and it had advisories for the rear shocks. The car currently has the optional self levelling suspension. I was going to order some standard rear shocks to replace, is it as easy as just disconnect the self levelling stuff and fit the normal ones?
Cheers
Re: Omega estate rear suspension
« Reply #1 on: 24 July 2011, 21:44:51 »
You may have issues with your spring length, sure they are matched to each other
pmc_3
« Reply #2 on: 24 July 2011, 22:00:41 »
Nah, the suspension is sitting level but the current dampers have had it they are starting to leak oil
2woody
  • Northumberland
« Reply #3 on: 25 July 2011, 00:16:59 »
even when deflated, your current dampers still add something to the spring rate and the ride height, so much so that the rear springs you have are of a softer rate then on the non-levelling cars, which is what the poster was meaning.
ideally, you should be changing the springs to the proper rate and ride height, too.
« Reply #4 on: 25 July 2011, 08:08:53 »
yes..
Every set of shocks, has springs to match,
iird, self levelling 'springs' will be longer than the normal ones.
so handling may be a bit too bouncy on regular shocks.
2woody
  • Northumberland
« Reply #5 on: 25 July 2011, 11:03:18 »
self levelling springs have a shorter installed length than normal ones
twiglet
  • Norwich, Norfolk
« Reply #6 on: 25 July 2011, 12:32:11 »
Cheers
Where abouts are you mate?
pmc_3
« Reply #7 on: 25 July 2011, 19:05:09 »
Ah right, didnt realise the springs were different.
I'm in Peterborough
