Author Topic: Multi ram question  (Read 1513 times)
lou
  • Romford
  • Always expect the unexpected
Multi ram question
« on: 25 June 2011, 17:44:23 »
Just been out doing the usual checks. When I blip the throttle the back actuator does not move but the front is moving at a certain speed. Checked all connection and Vac and all seems normal. Should the back one change when reved? All seems ok when driving and have not notice any changes.
bigegg
  • Leeds
    • MV6 RIP - Lexus GS300 '99
Re: Multi ram question
« Reply #1 on: 25 June 2011, 18:22:14 »
Mine is exactly the same - not sure if that's what it's supposed to do, as it may only activate "under load" rather than just a certain engine speed
Carpe Incendium
« Reply #2 on: 25 June 2011, 18:31:31 »
yes, they will both moved when revved (at different times)
good hard blip to full power should do it  :y
« Reply #3 on: 26 June 2011, 01:26:24 »
Need to be quite violent with the blipping to get the rear one to move ime.
Or get tech2 to test it remotely.
lou
  • Romford
« Reply #4 on: 26 June 2011, 12:33:56 »
Perhaps I was too gentle with the throttle as i did not rev the guts out of it. I will give it a go......
Aivaras
« Reply #5 on: 26 July 2011, 09:06:01 »
hallo to all.
the multi ram valve on the back of inlet manifold should open on 4100rpm, while other one near radiator opens on 3500rpm.
i have a problem with that on the inlet manifold, it shows no signs of working. it shoud work on idle speed and on 4100rpm as i said. the valve is working when i take off The throttle position sesnor (TPS) and i turn it with my finger, then valve opens, but when i put it back on throttle body, valve is not working again.. could someone explain that strange situation? please help.
