Author Topic: Rotten egg smell  (Read 3562 times)
old git
  • Shrewsbury
Rotten egg smell
« on: 08 July 2011, 18:56:38 »
Hi all
car has just started to misfire and has the rotten egg smell (realy strong ).It drove okay yesterday but noticed this morning.
First thought part of exhaust box collapsed /maybe rocker gasket prob.
any thoughts please
Dave
Re: Rotten egg smell
« Reply #1 on: 08 July 2011, 18:57:20 »
Cats?
old git
  • Shrewsbury
« Reply #2 on: 08 July 2011, 19:02:18 »
(Dogs) do you think a cat has collapsed
D
« Reply #3 on: 08 July 2011, 19:04:03 »
Could be mate - that smell is one of the symptoms  :(
Bionic
  • Leicester
  • Why drive anything else?
    • 1999 F/L 3.0 Elite saloon
« Reply #4 on: 08 July 2011, 19:17:32 »
From my experience with the same smell it was cat that had given up. Cost me two in the end too..OUCH :'(
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
« Reply #5 on: 08 July 2011, 19:22:20 »
If the cat is knac*erd, get it sorted asap or you will end up replaceing the centre section of the exhaust too  :y
Im talking from experience here  :'( :'( :'(
Twice  >:( >:( :'( :'(
old git
  • Shrewsbury
« Reply #6 on: 08 July 2011, 20:12:26 »
thanks so far
is it a pig of a job to change engine /cat down pipe also Recomend a good replacement make .shall check car tomo for misfire (maybe rocker cover prob)or just blocked exh.
Dave
old git
  • Shrewsbury
« Reply #7 on: 08 July 2011, 20:14:18 »
me again would replace complete system
D
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #8 on: 08 July 2011, 20:24:35 »
Try eternalcar on e bay  :y
A cat back system for a v6 (including twin tail pipes) will set you back about £120 delivered  :y
2 year warrenty  :y
tango
  • brum
« Reply #9 on: 08 July 2011, 23:17:42 »
it would smell if if its misfiring
you wanna check the why the misfire is there first
once the misfires cured the smell should disapear unless it has knackered the cat wich i dont think it should so quick
mac b
  • Burkshire
« Reply #10 on: 08 July 2011, 23:25:39 »
I wouldv thought the cat or maybe the aircon?  :question
Omega 2.2i CDX
fiend61
  • york
  • each to their own
    • 2.5cdx 3.0mv6 3.2vec c
« Reply #11 on: 09 July 2011, 07:27:58 »
a misfire smell would be of oil , if it was rocker gaskets, i dont know of any other smell a misfire would make, a rotten egg smell is usually the cats fubared, check the breakers on here for some to replace  :y
mikeh
  • London
    • 1999 V6 2.5 petrol MFL
« Reply #12 on: 09 July 2011, 13:45:42 »
Mine was misfiring and smelling of egg last year. Changed just the dispack and all ok. Passed MOT/Emissions last month.
old git
  • Shrewsbury
« Reply #13 on: 27 July 2011, 11:03:43 »
Just an update .the prob was a dis plug lead No.4,    center section of exh disintergrated (11 years, 60k not to bad a life).
So fitted new set Magnacor leads/plugs/new dis pack just incase(old looked perfect) /new hbv (old one 17k).checked breathers ect.Cat back exh system.Hopefully this will be it for a while, just need blood transfusion and skin grafts now.
Vx plug leads £100 + vat per side   :-? :o
Thanks
mikeh
  • London
« Reply #14 on: 27 July 2011, 18:19:59 »
Could someone please explain how the misfire/cat issue causes problems with the centre section of the exhaust.
Thanks, Mike.
