Author Topic: Can anyone help with a few Omega problems...?  (Read 1639 times)
llewellyn237
  • Teesside
    • 52 2.2 CD Auto
« on: 31 July 2011, 13:47:47 »
Please note that I'm no mechanic, I know very little and the car was bought as seen, no warranty...
 I've recently bought a 52 plate 2.2 Auto, there's a few things bugging me. The dash display is stuck 24.9 MPG, doesn't alter no matter what, is there any way to reset it? And the Engine Management light is on, after being hooked up to a computer to see what the problem is, it's saying Mass Airflow. After looking under the bonnet there's a cable unplugged from the Mass Airflow Meter, plugging this back in causes the car to almost stall and hardly move.
Any replies/advice/info would be greatly appreciated before I start to pay for it.
« Last Edit: 31 July 2011, 13:48:22 by OrganDonor »
Stallion
  • Romford
    • 3.2 Irmscher Elite
Re: Can anyone help with a few Omega problems...?
« Reply #1 on: 31 July 2011, 13:58:19 »
when you say the mpg screen doesnt move no matter what? do you mean the mpg figures dont go up/down after driving, or the mpg screen is frozen and doesnt display any other info such as range/cnst mpg etc??
llewellyn237
  • Teesside
    • 52 2.2 CD Auto
« Reply #2 on: 31 July 2011, 13:59:48 »
It does display other info such as range and outside temp. But the MPG never changes... always 24.9.
Stallion
  • Romford
« Reply #3 on: 31 July 2011, 14:04:02 »
Understood.. :y
On your stalk theres 2push buttons on the side, 1 which flicks through the different info's. 2 i forgot the use of that button but anyway. But when on the mpg screen push down and hold that button (not the one you pressed to flick through) and it should reset and hopefully change after you have driven it a while.  :y
« Last Edit: 31 July 2011, 14:06:33 by Stallion »
Stallion
  • Romford
« Reply #4 on: 31 July 2011, 14:05:18 »
as for the maf problem follow this link, do the pedal test and put up the codes on here!
http://www.omegaowners.com/forum/YaBB.pl?num=1189022687
llewellyn237
  • Teesside
    • 52 2.2 CD Auto
« Reply #5 on: 31 July 2011, 14:32:43 »
Thanks, I've reset the display as you instructed although the "pedal trick" isn't doing anything...
al brown
  • alton, hants
    • Rusty 97 3l estate
« Reply #6 on: 31 July 2011, 14:46:42 »
I am sure that the maf is knackered. Sure I remember a post saying if your car is running rough you need to disconnect it. If the car runs done with it unplugged then a new maf is needed. Worth posting a wanted ad in the test section and asking an admin to move it for you. Seem to recall that 2.2 doesn't support pedal trick
If it aint broken, you aint trying hard enough
« Reply #7 on: 31 July 2011, 14:49:04 »
Right...
for your average speed - press and hold the R button, it will reset to 0 and start on a new average for you.
MAF unplugged - causes it to run with a default map - not ideal.
plugging it in shows its knackered - therefore I would replace...
I would also recommend a decent make such as bosch rather than an ebay chinese cheapy.
al brown
  • alton, hants
« Reply #8 on: 31 July 2011, 14:54:41 »
Plenty of breakers on here will sell you a working second hand one for much less. As said put a wanted add in the test section and pm an admin to move it to sales and wants
Stallion
  • Romford
« Reply #9 on: 31 July 2011, 15:00:19 »
Right...
Much clearer, then again not my fault i havent used the stalk for a year or so, as my display is knackered  :D  :y
llewellyn237
  • Teesside
    • 52 2.2 CD Auto
« Reply #10 on: 31 July 2011, 15:18:08 »
Right...
Yeah thought so. Ordered Bosch one from my local parts seller  :y
Thanks for all the replies, much appreciated.
« Last Edit: 31 July 2011, 15:18:35 by OrganDonor »
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #11 on: 31 July 2011, 23:08:29 »
Yes,code reader required for the 2.2 :y
other rides
