Author Topic: 3.0 Tickover  (Read 1001 times)
  • Online Online
3.0 Tickover
« on: 03 August 2011, 11:24:10 »
Car has failed the MOT on 2 things, a missing back box.
http://www.omegaowners.com/forum/YaBB.pl?num=1312366774/0#0
Plus heavy steering on tickover.
How can I adjust the revs from arround 500 to 600/650
to see if it gets it throught the rest, (also wondering if if the problem might be an air leak some where)   :-/  TIA  :y
Re: 3.0 Tickover
« Reply #1 on: 03 August 2011, 11:51:39 »
Probably a tired pump mate.
Increasing revs might be a good enough bodge to get it through the MOT but not a long term fix.
Also wonder if doing that would skew emissions test result at idle..
Re: 3.0 Tickover
« Reply #2 on: 03 August 2011, 12:18:30 »
It should work fine at 500 RPM.
Idle speed is under ECU control. On some cars you can trim it with a Tech 2 but it can't be adjusted in the usual sense. Can you turn the climate on? Might help.
  • Online Online
Re: 3.0 Tickover
« Reply #3 on: 03 August 2011, 12:26:15 »
Totally agree James.  But if it gets tested, then I have AA Garage cover, a brandnew and fitted PS Pump will only cost me £25  ::)
hotel21
  • The Kingdom of Fife
Re: 3.0 Tickover
« Reply #4 on: 03 August 2011, 12:40:28 »
Steering input and assistance is also adjustable via tech2.  Not so sure if that will work at idle speed but guessing that it would.  :y
Re: 3.0 Tickover
« Reply #5 on: 03 August 2011, 12:50:59 »
Can you use the clips to adjust the throttle cable to slightly open the butterfly....I know its a bodge, but will up you rpm and hopefully fix the issue enough to get you through an MOT
Re: 3.0 Tickover
« Reply #6 on: 03 August 2011, 12:55:15 »
Yep, could also wind the throttle stop screw up a little, of course. [smiley=evil.gif]
Certainly a badge as the idle speed will probably be all over the place.
Page created in 0.024 seconds with 16 queries.
