Author Topic: Oil Sump Gasket  (Read 1065 times)
ajr3773
  • Northumberland
    • 3.0Ltr Auto Elite
Oil Sump Gasket
« on: 10 August 2011, 17:39:50 »
Anybody know the GM part number for an oil sump gasket for a 3.0ltr V6 Omega.
Just been quoted £36.00 which i think is a little steep for what it is. (Is this about right or not?)
Do JPAT do them or do they only do transmission parts.
Can anybody recommend a decent supplier at a resonable cost?
Thanks in advance.
« Last Edit: 10 August 2011, 17:40:44 by ajr3773 »
Re: Oil Sump Gasket
« Reply #1 on: 10 August 2011, 17:43:42 »
Dont - use sealant - grey iirc...
Looknee and others have had problems when using gaskets, sure they are obsolete now and superceeded with sealant  :y
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
Re: Oil Sump Gasket
« Reply #2 on: 10 August 2011, 20:48:22 »
I think you are refering to the Sump Casting to Block Gasket, which Vauxhall will sell you a rubber gasket that will leak when fitted >:( I then found that the Grey Sealant that is used on Oil Cooler Plates is used now instead of the rubber gasket. There was an update on Vauxhalls computer which the guy didn't see  ::)
From how I understood the OP he ment the Sump Gasket a little different and a few hours more work  ;D :-?
« Last Edit: 10 August 2011, 20:49:27 by Loo-knee »
