Author Topic: New key fob  (Read 2972 times)
Bob G
  • Gloucester
New key fob
« on: 24 August 2011, 18:56:33 »
had to replace the key fob that came with car, does the new one need Tec2 programming? key is orginal with transponder and still works
Re: New key fob
« Reply #1 on: 24 August 2011, 18:58:13 »
Just the casing, no. New internals in the fob, yes.
Bob, being a 2.0 you will need everything for cruise not just a stalk. Need to find a 2.0 CDX as a donor
« Last Edit: 24 August 2011, 19:02:53 by RobG »
Bob G
  • Gloucester
Re: New key fob
« Reply #2 on: 24 August 2011, 19:43:49 »
Yes the internals were a black soggy mess so new internals
I thought that as it is a facelift it would not need anything else, it does not have a throttle cable as illustrated in the how to section so assumed that all was well, obviously not  :( what else is needed)
Guess key will be a Newent job then I hope
Re: New key fob
« Reply #3 on: 24 August 2011, 19:47:05 »
Cruise motor with bowden cable, bracket on throttle body for the cable and ideally the mounting bracket for the cruise motor. You will only get this from a 2.0 CDX spec
Re: New key fob
« Reply #4 on: 24 August 2011, 20:20:49 »
You sure no throttle cable?
Re: New key fob
« Reply #5 on: 24 August 2011, 20:23:39 »
The gallery pics, at a glance, look like 2.2  :-/
Bob G
  • Gloucester
Re: New key fob
« Reply #6 on: 24 August 2011, 20:27:36 »
Well two of us searched in vain today and can find nothing, assuming that we are looking in correct location, left of engine as you view from front, other person looking is ex AA and does know his stuff but we are prepared to be wrong :D
Re: New key fob
« Reply #7 on: 24 August 2011, 20:27:37 »
That confused me too. If his car has no throttle cable, where would the bowden cable of a cruise control kit fit?  :-?
Re: New key fob
« Reply #8 on: 24 August 2011, 20:27:41 »
agreed - no flame trap as per 2.0  :-/
Re: New key fob
« Reply #9 on: 24 August 2011, 20:29:14 »
ok...
why do you think its a 2.0?
pm me your reg please, Ill check what it should be  :y
Re: New key fob
« Reply #10 on: 24 August 2011, 21:02:07 »
2.0ltr. Look at OP`s engine pic in gallery
Re: New key fob
« Reply #11 on: 24 August 2011, 21:02:31 »
Well just checked, and this left VX with a 2 Litre.
X20XEV serial number 31105679
who knows whats happened since then  though
Bob G
  • Gloucester
Re: New key fob
« Reply #12 on: 24 August 2011, 21:06:47 »
pic of my engine in the gallery, i think that best way forward is to wait till newent and then let those in the know look, but i am blowed if i can see a throttle cable.  :o
Re: New key fob
« Reply #13 on: 24 August 2011, 21:14:36 »
It emerges from the bulkhead, you won`t see it at the throttle body unless you remove the air intake pipe (big black fat one on top of TB)
Bob G
  • Gloucester
Re: New key fob
« Reply #14 on: 24 August 2011, 21:17:43 »
ok Rob wil try that tommorow.
