Author Topic: Diff ratio  (Read 1986 times)
Diff ratio
« on: 24 August 2011, 22:03:55 »
year 2000 2.5 auto saloon. Anyone know what the ratio will be. I think its 4.22/1 but want to check.
Tia. :y
Re: Diff ratio
« Reply #1 on: 24 August 2011, 22:08:32 »
not sure but can be 3.9 also.. :-/
Re: Diff ratio
« Reply #2 on: 24 August 2011, 22:10:21 »
How to find out is the problem. :-/
Re: Diff ratio
« Reply #3 on: 24 August 2011, 22:19:45 »
I remember its mostly 3.9.. 4.22 must be LSD and rare I think..
Re: Diff ratio
« Reply #4 on: 24 August 2011, 22:22:44 »
Jack up rear of car, Disconnect propshaft, rotate Diff input shaft x turns, count rotation of rear wheels y .... calculate ratio x : y
Seeemples ...   :)
« Last Edit: 24 August 2011, 22:23:12 by entwood »
Re: Diff ratio
« Reply #5 on: 24 August 2011, 22:50:58 »
Tia. :y
If similar to the face lifts, an auto would be 4.2. Maybe uncle Jimbob could confirm.  :y
twiglet
  • Norwich, Norfolk
Re: Diff ratio
« Reply #6 on: 24 August 2011, 22:56:19 »
Tia. :y
I believe the car Albs is referring to is a facelift.  :y
Re: Diff ratio
« Reply #7 on: 24 August 2011, 22:59:02 »
Tia. :y
Sorry, specifically the 2.6 auto. The drive by wires are listed in FAQ for the correct gearing. I would think the 2.5 would be the same. But that's an assumption.
Re: Diff ratio
« Reply #8 on: 24 August 2011, 23:09:22 »
Tia. :y
Memory fading Albs ;D ;D
http://www.omegaowners.com/forum/YaBB.pl?num=1305271390/0
Re: Diff ratio
« Reply #9 on: 24 August 2011, 23:19:37 »
I can honestly say that I have no recollection of that thread at all, or even why I asked the question. :-[
Looks like 4.22 is correct then. :) Thanks all. :y
kcl
  • Finland
    • Volvo V60 D4 -14
Re: Diff ratio
« Reply #10 on: 25 August 2011, 06:59:39 »
There's a plate on the diff with different markings/digits on it and somewhere on this forum there's a table telling which code is which ratio...
Re: Diff ratio
« Reply #11 on: 25 August 2011, 08:39:06 »
pm me your reg....ill let you know what it left the factory with  :y
Re: Diff ratio
« Reply #12 on: 25 August 2011, 10:38:18 »
Brilliant, thanks Jimbob.Will do that right now. :y
Re: Diff ratio
« Reply #13 on: 25 August 2011, 18:54:15 »
And the answer is.....?
Re: Diff ratio
« Reply #14 on: 25 August 2011, 19:02:41 »
standard 4.22:1  :y
