Author Topic: fuel filter changs  (Read 1700 times)
Ian Rycroft
fuel filter changs
« on: 29 August 2011, 19:18:24 »
i need to change my fuel filter on my estate,it looks hard to get at,is it a tricky job,also need to replace the leak off pipes,are they 3.2mm or 3.5mm pipes and is it easy to do
Re: fuel filter changs
« Reply #1 on: 29 August 2011, 19:42:50 »
fuel filters not bad on an estate...
clipped up by the diff.
undo the fiddly clips - have spares to use  :y
replace, making sure they flow the same way  :y
« Reply #2 on: 29 August 2011, 19:56:11 »
Not sure dti is same as petrol ;)
Ian Rycroft
« Reply #3 on: 29 August 2011, 19:57:38 »
ok i think i know what you mean? i had a look and thought i had to remove the header tank and undo the torx bolt on top of the filter housing and just drop the bowl off,i just can not see how you get your hand in to do the job
« Reply #4 on: 29 August 2011, 19:59:48 »
oops yes, was refering to v6 petrol sorry
Brikhead
  • West-Mids.
  • Sleeping. Do not disturb.
    • 2003 chitroen Saxo
« Reply #5 on: 29 August 2011, 20:01:20 »
Usually the fuel filter is located quite high up on most diesel Vx's, think it's to try and create a reservoir to help 'em to start more easily...
Is the filter located up on the bulkhead? Doesn't the top just come off?
Ian Rycroft
« Reply #6 on: 29 August 2011, 20:07:28 »
not by the look of it,also it mounted on the inner wing and realy tight for room
Brikhead
  • West-Mids.
« Reply #7 on: 29 August 2011, 20:13:36 »
Ahh, Sorry Mate, to be honest I've never even seen a diesel Omega from inside the engine bay, Cavaliers and Vectra's on the other hand...
 ;D
Where abouts in the country are you? Perhaps a friendly Forum Member may be located near by to lend a hand?
Ian Rycroft
« Reply #8 on: 29 August 2011, 20:17:44 »
isle of man
Ian Rycroft
« Reply #9 on: 29 August 2011, 20:30:01 »
i want to do these 2 jobs as if i leave it more than 2 days the thing wont start >:(
freecall666
  • looking over your shoulder
    • 2.0l sweat tank on wheels
« Reply #10 on: 30 August 2011, 00:57:30 »
also make sure you got some new rubber seal or after you do the job can start leaking.
there are blue type and red type, just afew coppers :y
Solar charger fitted.
If not Broke dont fix it..
Ian Rycroft
« Reply #11 on: 30 August 2011, 22:23:32 »
hi thanks for that,can you tell me where these rubber seals go,thanks
freecall666
« Reply #12 on: 31 August 2011, 00:08:29 »
when you get pipes off  the rubber seal may split and come off with the filter, they inside the plastic housing, when you get new ones in they a bit fiddely have to make sure they in right or when the new filter on, then the new filter will cut them and then leaks. cannot remeber part number but went to vauxhall and they had them it.... there are green ones awell. :y
Page created in 0.089 seconds with 16 queries.
