Author Topic: please help strange noise on front wheel  (Read 1491 times)
griff2494
  • fallingbostal,germany
« on: 11 September 2011, 15:44:37 »
hi all
went for a drive today (first real one since the hgf and rad failure :-( )
anyway the car ran like a dream,no water loose,over heating nothing :-)
but i got a strange clunking/rattling noise from the front pass  wheel,was that worried i made the wife drive !!!!! (pmsl, but only so i could put my head out the window to lisen to the noise as it only happened on unlevel/cloble ground )
anyway thought it could only realy be a few things
1.  something loose
2.  brake retaining clips broke
3.  wheel bearing
4.  disk its self loose
5.  shock knackered
anyway had a quick look and got a bar to lever on all the joints etc ,nothing !!!!
brakes all fine and bolts tight
shock looks good ,no oil leaks etc and when bouncing the front of car all seems spot on and returns to correct height etc so well happy
BUT then i put my hands up on the spring on the shock :-(
and found this
the very bottom of the spring has snapped off  :o :o :o
not sure why or when this has happened but as you can see it most of spanned a while ago
any ideas why this would of happened???????????
do i need to replace it asap? now ive removed this the noise has stopped and the car still seems to drive,steer and brake just fine no pulling to that side etc
cheers
griff
Re: please help strange noise on front wheel
« Reply #1 on: 11 September 2011, 15:59:53 »
cheers
griff
Your profile says you're in Germany, I can only assume that their roads are as bad as they here in Blighty! I'm afraid that broken springs are generally a result of wear & tear due to pot holes etc. You need to replace BOTH front spring sooner rather than later really. You now have odd springs which can result in un-even suspension movement which can cause imbalance of braking.
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #2 on: 11 September 2011, 16:02:24 »
Yes do both sides asap not too expensive as long as you do not go to main dealer I fitted KYB on my rear
griff2494
« Reply #3 on: 11 September 2011, 16:20:00 »
thanks for your replies
thought u may say that lol :-(
been on ebay there about £45 each side
comp tool £12 so both sides for around £100 if i do it my self,from what i can see it looks a very easy straight forward job
am i right in thinking the only spec tool i need is a coil spring compressor ???????
cheers again
griff
« Reply #4 on: 11 September 2011, 16:25:15 »
cheers again
griff
Not done an Omega's, but nothing other than the spring compressor for an Astra or Smart.
Don't go too cheap with the spring compressors though, Omega's springs are quite hefty.  :y :y
Agemo
  • Cleethorpes
  • Insignia
« Reply #5 on: 11 September 2011, 17:31:09 »
Easy enough job, but you will need a spring compressor. You may be able to borrow one  ::). Remember your can will need a full geometery set-up afterwards unless you are VERY lucky.  :y
Sam Burton
  • St Neots, Cambridgeshire
  • Just Car Mad Really
    • Many
« Reply #6 on: 11 September 2011, 17:32:13 »
Depending how old the Omega is its not uncommon trust me to have a spring randomly go the last of the vectras were splitting the springs like nothing in one week i changed over 5 springs on over 8 different Vectras!!! so its not uncommon. :-/
Drives: 2015 Vauxhall Cascada Elite 2.0 CDTI Auto, 2006 Vauxhall Vectra 2.8T VXR 'Ex-Police' Build, 2010 Vauxhall Insignia 2.8T VXR Saloon, 2017 Vauxhall Insignia Elite VX Line Sports Tourer 2.0 CDTI Auto
griff2494
« Reply #7 on: 11 September 2011, 18:44:30 »
its a 2.216v auto on a 2002 plate
