Author Topic: door check strap  (Read 1121 times)
shadwell1981
  • leeds, west yorkshire
  • welsh man in town!!
door check strap
« on: 20 September 2011, 12:49:34 »
hi
i have tryed to search for any posts but have gained nothing. my drivers front door check strap is making a god awful noise and the door does not want to open fully. with a big push it will open. is it simply door card removal and undo some bolts or is it a bigger job than that? local scrap yard did have omega in, but not called to see if its still there.
thanks once again if you could help.
« Last Edit: 20 September 2011, 12:55:51 by RobG »
shadwell1981
Re: door check strap
« Reply #2 on: 20 September 2011, 14:09:47 »
thank you!! just going out to the car now to check the door and might have a trip to local dealers to get the parts ordered.
thanks once again.
« Reply #3 on: 20 September 2011, 14:34:41 »
May not be the bush.The check strap may have ripped out of the door. ;)
http://www.omegaowners.com/forum/YaBB.pl?num=1312810743/0
« Last Edit: 20 September 2011, 14:38:23 by albitz »
shadwell1981
« Reply #4 on: 20 September 2011, 16:28:13 »
you are quite right. it has ripped out, only on three sides but is getting weaker. i just got back from dealers and they said to weld it back together. i have not ordered the plates and screws, should i order them and try the repair anyway?
« Reply #5 on: 20 September 2011, 18:20:30 »
.... should i order them and try the repair anyway?
YES! It's a lot easier to use the plates now before the door rips out completely.  :y :y
shadwell1981
« Reply #6 on: 20 September 2011, 20:18:59 »
right then, dealers here i come (again).
