Pages: 1 [2] 3  All   Go Down
Author Topic: Problems painting interior trim  (Read 5162 times)
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
Re: Problems painting interior trim
« Reply #15 on: 21 September 2011, 18:20:21 »
Hi mate,
I'm not a lover of the walnut trim on my elite and fancied something different. As mentioned above, I rubbed the plastic down, grey primer then several coats of silver and finished off with several coats of laquer.
I think it's worth doing, but each to their own. I reckon you should get a spare set of plastics for your car and give it a go, if you don't like it put the other set back  :y
This is mine:
HTH  :y
Keep in mind that this is a prefacelift, whereas mine is a year 2000 facelift with different dash.
still the same principle mate  :y
ive got to say that the stereo removal is easy but youll need a special tool to get your stereo out (see e bay ''vaux omega stereo remover''.
also if you replace the ashtray, gear surround and stereo surround are you still not going to be left with the fake walnut on your door trim? just wondering if this will look a bit silly?  :-/ worth thinking about!!!  :y
RIP Paul Lovejoy
Webby the Bear
  • Northampton
« Reply #16 on: 21 September 2011, 18:21:22 »
ps nice job blackviper!!! i like that!!!  :y :y :y :y
RIP Paul Lovejoy
blackviper90210
  • Bromsgrove, West Midlands
    • 03 3.2 Elite Saloon
« Reply #17 on: 21 September 2011, 18:23:30 »
I realise that mate, I did the same to my facelift saloon I had before this one. Def worth a go though  :y
AKA - Mr Bracket
blackviper90210
« Reply #18 on: 21 September 2011, 18:25:05 »
Cheers mate  :y
I just need to do the door inserts next. The colour I've picked is Audi Aluminium. Pretty chuffed with the result  ::)
AKA - Mr Bracket
blackviper90210
« Reply #19 on: 21 September 2011, 18:27:00 »
Hi mate,
This is mine:
HTH  :y
The door trims on the facelift are dead easy. I just popped them off and did the same as the centre console. Unfortunately, I've been told my prefacelift door trims are riveted, so the door cards have to come off  :(
AKA - Mr Bracket
Webby the Bear
  • Northampton
« Reply #20 on: 21 September 2011, 18:28:15 »
Cheers mate  :y
really nice colour and looks a very good job.
is it just car paint youve used (like the spray cans from halfoirds)? if so do you know the best way to get an even cover as im having hell with my rear wing (external)
RIP Paul Lovejoy
« Reply #21 on: 21 September 2011, 18:40:58 »
agreed.. very good color selection :y
blackviper90210
« Reply #22 on: 21 September 2011, 18:50:49 »
I've never sprayed panels before so not the one to ask, lol.  I've used Halfords paint for the trims on mine though, but been very lucky with the finish I think.
I just gave it several light coatings in no particular order, then the same again with the laquer. Quite lucky that it didn't come out shoddy really  ::)
AKA - Mr Bracket
Webby the Bear
  • Northampton
« Reply #23 on: 21 September 2011, 18:52:31 »
fair play mate. ive done 3 coats of paint but then when i lacquered it im left with a really abrasive finish and dont know what to do other than to do it again and not put lacquer on!!!  :'(
RIP Paul Lovejoy
blackviper90210
« Reply #24 on: 21 September 2011, 18:55:31 »
I was advised that after each coat of paint to use either 800 or 1000 wet & dry and gently rub it down. Then respray. This gives a very light rough surface for the next coat to stick too.
Then on the last coat, don't rub it down, leave it. When ready, give it several coats of laquer. Thats all I know I'm afraid.  :-/
AKA - Mr Bracket
Webby the Bear
  • Northampton
« Reply #25 on: 21 September 2011, 18:57:34 »
thanks B. Viper.... ill give that a go  :y :y :y :y
RIP Paul Lovejoy
blackviper90210
« Reply #26 on: 21 September 2011, 19:03:03 »
Hi all, i have just started to tidy up the interior of my facelift miggy while it is off the road temporarily. Being a GLS, all of the walnut trim in the centre of the car was covered in a funny rubber/plastic like substance which was all scratched and peeling, showing the walnut effect beneath. I have removed the tray around the gear lever and completely stripped it of the said substance, and then sanded it. Next i used some GM grey primer spray as i want to paint it Red (not to everyone's taste). The problem is that in certain spots, the paint is not sticking and looks aerated (small holes like air bubbles). Can anyone tell me what if anything i am doing wrong???? :-? :-? :-? :-? :-?
Thanks.
The only thing I can think thats causing you this problem is it's possibly greasy/dirty surface.
Try rubbing it back down and using a degreaser to clean it, then primer it and top coat etc and see how that goes.  ;)
AKA - Mr Bracket
« Reply #27 on: 21 September 2011, 19:26:58 »
I'm afraid.  :-/
correct..  :y :y
Broomies Mate
  • Bristol, UK
    • Stuff!
« Reply #28 on: 21 September 2011, 20:49:03 »
After the final coat of lacquer, you need to 1200grit wet sand the area.  Use a drop (and I mean just a drop) of washing up liquid in say a litre of water to help the paper glide over the surface.
You then need to 'buff' ideally using a couple of grades of cutting paste and either a lot of elbow grease or an electric 'mop'.
It isn't really necessary to sand between coats, especially the base coats.  A 800grit paper will remove a dust-coat with a couple of passes, completely defeating the object of 'dust-coating'.
Remember, the area to be sprayed needs a key.  Lightly use a scotchpad on the area and the area immediately surrounding to key it.  Any marks will be removed when mopped with cutting paste.
Webby the Bear
  • Northampton
« Reply #29 on: 21 September 2011, 20:55:40 »
cheers BM. When i ''lightly sand'' using the 1200 grit.... should i be ''rubbing it down'' or just a once over light job? :y
RIP Paul Lovejoy
Pages: 1 [2] 3  All   Go Up
