Pages: 1 2 [3]  All   Go Down
Author Topic: Problems painting interior trim  (Read 5179 times)
Broomies Mate
  • Bristol, UK
    • Stuff!
Re: Problems painting interior trim
« Reply #30 on: 21 September 2011, 21:07:53 »
cheers BM. When i ''lightly sand'' using the 1200 grit.... should i be ''rubbing it down'' or just a once over light job? :y
The lacquer should be hard as nails!  It will easily take quite a bit of abuse once dry.  The residue from sanding lacquer is white, it will turn your lubricant (the water) a milky colour.  Thats perfectly normal.... just sand the freshly sprayed area evenly.  If you get a residue which is your paint colour, you have gone too far!  ;D
It's easier to stop sanding before you think it's perfect and then using the cutting paste, stand back and think "I'll give that another rub down" than to go too far and think "rollox, I'll get the spray gun back out"  ;D ;D
Interestingly, lacquer needs to be applied a lot heavier than most people think..... certainly much heavier than the base-coat.  3-4 decent coats of lacquer is perfect IMO.  Some people prefer 6-8coats of lightly applied lacquer, but I dont think that gives enough depth.  Obviously, you are more prone to getting runs in the lacquer if it is applied heavily.
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #31 on: 21 September 2011, 21:23:39 »
thanks mate so basically its normal for the lacquer to be abrasive and frankly looking rough as houses until sanded down????  :-/
that makes sense cos it looked really good till i lacquered it!!!  ;D
RIP Paul Lovejoy
Broomies Mate
  • Bristol, UK
    • Stuff!
« Reply #32 on: 21 September 2011, 21:34:43 »
I presume you are using Acrylic Lacquer and Base Coat?
If so, after applying the lacquer, you should have some form of shine, but the surface will not be smooth like glass.  Thats where the cutting comes in.
If the finish is flatter than a Witch's chest and duller than ditch-water, then there isnt a good enough depth of lacquer.  :y
Webby the Bear
  • Northampton
« Reply #33 on: 21 September 2011, 21:42:33 »
cheers mate. im going to post some pics tomorrow cos im sure something aint tickety-boo!!!!!
cheers BM  :y :y :y
RIP Paul Lovejoy
Lesopc
  • West London
  • Worlds Biggest GM Fan
« Reply #34 on: 21 September 2011, 23:49:31 »
Hi mate,
I'm not a lover of the walnut trim on my elite and fancied something different. As mentioned above, I rubbed the plastic down, grey primer then several coats of silver and finished off with several coats of laquer.
I think it's worth doing, but each to their own. I reckon you should get a spare set of plastics for your car and give it a go, if you don't like it put the other set back  :y
This is mine:
HTH  :y
Keep in mind that this is a prefacelift, whereas mine is a year 2000 facelift with different dash.
still the same principle mate  :y
ive got to say that the stereo removal is easy but youll need a special tool to get your stereo out (see e bay ''vaux omega stereo remover''.
also if you replace the ashtray, gear surround and stereo surround are you still not going to be left with the fake walnut on your door trim? just wondering if this will look a bit silly?  :-/ worth thinking about!!!  :y
The door trims are black and in good shape (mines a GLS).
Why oh why was there never a V8 Omega????
Such a missed oppurtunity.
Look forward to the Cadillac ATS & ATS-V. Maybe a re-badged one will replace the Miggy as a RWD runner?
Lesopc
  • West London
« Reply #35 on: 21 September 2011, 23:50:21 »
Thanks all. I think i've decided what to do now. I'll post pics when complete. :y :y :y :y :y :y :y :y :y :y
blackviper90210
  • Bromsgrove, West Midlands
    • 03 3.2 Elite Saloon
« Reply #36 on: 22 September 2011, 08:13:51 »
Nice one mate, looking foward to seeing the results  :y
AKA - Mr Bracket
Pages: 1 2 [3]  All   Go Up
