Pages: [1] 2 3  All   Go Down
Author Topic: Problems painting interior trim  (Read 5158 times)
Lesopc
  • West London
  • Worlds Biggest GM Fan
« on: 21 September 2011, 10:20:56 »
Hi all, i have just started to tidy up the interior of my facelift miggy while it is off the road temporarily. Being a GLS, all of the walnut trim in the centre of the car was covered in a funny rubber/plastic like substance which was all scratched and peeling, showing the walnut effect beneath. I have removed the tray around the gear lever and completely stripped it of the said substance, and then sanded it. Next i used some GM grey primer spray as i want to paint it Red (not to everyone's taste). The problem is that in certain spots, the paint is not sticking and looks aerated (small holes like air bubbles). Can anyone tell me what if anything i am doing wrong???? :-? :-? :-? :-? :-?
Thanks.
Why oh why was there never a V8 Omega????
Such a missed oppurtunity.
Look forward to the Cadillac ATS & ATS-V. Maybe a re-badged one will replace the Miggy as a RWD runner?
Re: Problems painting interior trim
« Reply #1 on: 21 September 2011, 10:22:28 »
Try spraying plastigrip adhesion promoter on it first. :y
« Reply #2 on: 21 September 2011, 10:29:24 »
Thanks.
Whatever floats your boat
« Reply #3 on: 21 September 2011, 10:31:15 »
Thanks.
Yeah that blends in well  :-X  ;D
« Reply #4 on: 21 September 2011, 10:51:23 »
yep..  :y
sanding the surface with 420 or 800 then plastigrip and then normal paint.. or paint wont stick to surface..
ps: if you wont apply a base layer after plastigrip, use 1200 ..
« Last Edit: 21 September 2011, 10:52:41 by cem_devecioglu »
twiglet
  • Norwich, Norfolk
« Reply #5 on: 21 September 2011, 10:55:33 »
No offence intended mate, but it will never look anything more than a dogs dinner if you paint these parts.  They are high use areas, and need to be able to resist damage from finger nails, keys, phones, etc.
Why don't you just replace the gear level surround, stereo surround and ashtray cover (all shown in red in Rob's pic above) with a decent secondhand set?
I have a full set available here in both walnut (elite) and brushed silver (mv6), which you can buy for probably less than you will spend on all the paint and primers you're looking at buying.
PM me if you are interested.
Cheers  :y
Lesopc
  • West London
« Reply #6 on: 21 September 2011, 11:37:11 »
Cheers  :y
I like the sound of brushed silver, does this mean all three parts (ashtray cover, gear surround and stereo surround)?
What would you charge for supply and postage?
Also, how do you remove the stereo surround part as i have gently tried to prize with a screwdriver but it seems stuck fast??? :-? :-? :-? :-?
« Last Edit: 21 September 2011, 11:38:30 by Lesopc »
Osprey
  • Redhill, Surrey
  • Drink up. The world's about to end.
    • 01 2.6 Elite saloon
« Reply #7 on: 21 September 2011, 11:39:54 »
I feel like a military academy. Bits of me keep passing out.
Lesopc
  • West London
« Reply #8 on: 21 September 2011, 11:42:22 »
Is this any help?
http://www.omegaowners.com/forum/YaBB.pl?num=1152745540
Helps a lot. Thanks.
twiglet
  • Norwich, Norfolk
« Reply #9 on: 21 September 2011, 11:45:51 »
Cheers  :y
You can have all 3 parts for £30 delivered mate.  :y
To remove the stereo surround...
While you are at it, are the buttons on you climate control panel all worn away? If so I have a mint one here that I will throw in for an extra £15.  :y
Lesopc
  • West London
« Reply #10 on: 21 September 2011, 11:47:44 »
Cheers  :y
Only the on/off button (now white plastic). I'll let you know. Thanks.
twiglet
  • Norwich, Norfolk
« Reply #11 on: 21 September 2011, 11:55:02 »
Cheers  :y
Sorry, just to clarify. For £15 you get the complete climate control unit (which comes out with the stereo surround), not just the buttons.
I can install the one I have here into the brushed silver surround for you before I send it if you like. Then you can keep your unit as a spare.
Cheers.  :y
Lesopc
  • West London
« Reply #12 on: 21 September 2011, 11:58:19 »
Cheers  :y
Cheers.  :y
I'll give it some thought and let you know. :y :y :y :y :y
blackviper90210
  • Bromsgrove, West Midlands
    • 03 3.2 Elite Saloon
« Reply #13 on: 21 September 2011, 15:09:13 »
Hi mate,
I'm not a lover of the walnut trim on my elite and fancied something different. As mentioned above, I rubbed the plastic down, grey primer then several coats of silver and finished off with several coats of laquer.
I think it's worth doing, but each to their own. I reckon you should get a spare set of plastics for your car and give it a go, if you don't like it put the other set back  :y
This is mine:
HTH  :y
« Last Edit: 21 September 2011, 15:11:56 by blackviper90210 »
AKA - Mr Bracket
Lesopc
  • West London
« Reply #14 on: 21 September 2011, 18:11:09 »
Hi mate,
This is mine:
HTH  :y
Keep in mind that this is a prefacelift, whereas mine is a year 2000 facelift with different dash.
Pages: [1] 2 3  All   Go Up
