Author Topic: CCR 2006 replacement, CD30?  (Read 7600 times)
Andyswad
  • Ashby de la Zouch ish
« on: 22 April 2008, 18:15:05 »
What to replace my ccr 2006 with?
Can the newer models eg cd30 Mp3, CDR 2005 fit or am I restricted to older models only?
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
Re: CCR 2006 replacement, CD30?
« Reply #1 on: 22 April 2008, 19:05:27 »
You cannot fit a 2 digit stereo at all, CD30 etc
Some four digit stereos may require additional display etc to be purchased and configured also.
Radio & Decoding Technician
www.dndservices.co.uk
alexandjen
  • Sittingbourne, Kent
  • The Silver Surfer
« Reply #2 on: 22 April 2008, 20:08:03 »
I have replaced my CCR 2006 with a CDR 2005 and all works fine  :y
« Last Edit: 22 April 2008, 20:08:21 by alexandjen »
Trade club card holder
Code scanner available
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #3 on: 22 April 2008, 20:22:30 »
CDR2005 is an excellent choice - simple plug and play swap over - no wiring alterations and no fuss - all you need is the security code with the new unit. :y
MutantCav
  • Gainsborough
« Reply #4 on: 22 April 2008, 21:15:46 »
Or CCR800 Bose one (have one here with code), also plug and play...depends upon what you want from the head unit...
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #5 on: 22 April 2008, 21:29:55 »
Not sure thats going to work?
Isn`t the CCR800 a single DIN with the 10 pin ISO connector?
The CCR???? are double din with 36 pin Mini ISO connnectors !
MutantCav
  • Gainsborough
« Reply #6 on: 22 April 2008, 21:55:18 »
Isnt the above a contradiction?? lol
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #7 on: 22 April 2008, 21:58:12 »
probably, but its late and I`m tired    :P
MutantCav
  • Gainsborough
« Reply #8 on: 22 April 2008, 22:02:18 »
Although just re read the initial bit and its a CCR2006, was thinking CCR600 which has the 800 as a direct upgrade...its late and I'm tired! lol
Interesting to know about the CDR2005 being a direct upgrade for CCR2006...worth remembering
« Last Edit: 22 April 2008, 22:05:51 by ShieldOfSteel »
« Reply #9 on: 22 April 2008, 22:05:27 »
changing from CCR600/800 to CCRT700/CCR200x/CDR2005/NCDC series (or vice versa) is not straightforward.
    • 530D M Sport, 330i Coupe
« Reply #10 on: 22 April 2008, 22:36:49 »
Downgrade surely... You lose the tape deck (shame) and go from four discs to one.... supposed to be more reliable though!
davlad22
  • Sunny Yorkshire
« Reply #11 on: 23 April 2008, 12:51:44 »
Yep, that's a downgrade!
....and our 2005 failed a few weeks after purchase also. It's a piece of electronics, they're ALL subject to problems.
So we had it replaced under waranty for a 2006, different cage required though.
So, is our '03 DTi Elite likely to have any wiring for an Siemens NCDC2013/2015 Sat nav unit???. At present, it's also got a 2006.
Jay w
  • Plymouth/Poole
  • omega gone
« Reply #12 on: 23 April 2008, 16:34:27 »
I wouldn't have thought so.
The NCDC series required a RGB cable if it was connected to a colour screen, i doubt that would be fitted if the car was not supplied with the sat nav set up
davlad22
  • Sunny Yorkshire
« Reply #13 on: 25 April 2008, 20:34:32 »
I wonder if it's got wiring for a phone or perhaps the sat nav antenna then??? Might be worth a look some day.
