Author Topic: Autobox ECU - GS820  (Read 2185 times)
Autobox ECU - GS820
« on: 04 May 2008, 21:03:43 »
Should it fire up if supplied with power?
Used Haynes to wire up power, and diag line, but tech2 won't talk to it :(
    • 530D M Sport, 330i Coupe
Re: Autobox ECU - GS820
« Reply #1 on: 04 May 2008, 21:53:10 »
You would have thought so! What is the true 0V? Chassis or a pin on the connector?
« Reply #2 on: 04 May 2008, 21:54:47 »
Its wired up to a car battery (only)...
« Reply #3 on: 04 May 2008, 22:29:01 »
Does the Diag line normally route directly to pin 7 on the diag socket or is it interfaced through the engine ecu or similar?
Just wondering if there is any protocol conversion going on as a lot of the ECU's interface on the same pin and I don't really understand how they co-exist.  :-[
« Reply #4 on: 04 May 2008, 23:39:53 »
Has it got both switched and permanent 12v supplies to it? :-/
« Reply #5 on: 05 May 2008, 07:07:48 »
Has both 12v and switched 12v, as per Book of Lies.  Wires directly to diag pin, as do all the other ecus on non CAN cars...
