Air Con Temp
Started by Mr Skrunts, 20 May 2008, 21:35:38
Been out for th 1st time today in the Elite.
Been out all day and just put the climeat to Lo on both sides and swiched on the Auto.  All has been fine all day, both outside dials shining brightly.
The only thing I have altered is the fan speed down to 2.
Got home tonight, done arround 70 miles during the day, stopping here and there and viiting a mates, got home tonight and saw the right hand te,p display lights had either gone out or gone really dim (not sure at this point.)
Any thoughts as to what might be the cause.
Picture taken just as I had up the temp from Lo, I also noticed that the temp on the left altered with it at the same time.
Will the cup holder make any difference to the sampling fan operation?
TIA  :y
JonArgraig
Blub has gone mate
Cheers Jon, glad it's nothing major then.
Are they a big job to replace?
Has anyone got any pics /instructions on how to change the bulbs?
TIA.   :y
Check the Maint guides, there is one for the bulbs, generally recommended to do all 5, as chances are you replace 1, disturbing the others may well knock another one off  :y
QuoteCheck the Maint guides, there is one for the bulbs, generally recommended to do all 5, as chances are you replace 1, disturbing the others may well knock another one off  :y
http://www.omegaowners.com/forum/YaBB.pl?num=1162120610
There are 2 bulb part numbers advised.  which one(s) do I go for.?
TIA.   :y
amba
Sorry to hi-jack the thread,but on a slightly different note,i like the look of that drinks holder you have fitted on the airvents.
Is it secure enough to hold drink whilst driving and where/howmuch was it?Hi-jack over.!!
No worries with a McD Drink or Flurry stood in it.
Cans no probs at all.
Nice strong hooks push into the vents and then are held in place with spring back plate's
