Author Topic: SC804 and CD Changer  (Read 2436 times)
MutantCav
  • Gainsborough
« on: 30 June 2008, 20:23:18 »
Right, I have a CDR500 in my tourer...SC804 just plugs straight in place...but whats involved in putting the 6cd changer in the car, and will the lead be long enough to fit in the estate as it will come from a saloon?? Plus where would it fit on an estate?
RobC_NE
  • North East
  • IMI and VSIB Qualified Auto Electrician
Re: SC804 and CD Changer
« Reply #1 on: 03 July 2008, 00:52:00 »
cant guarantee it will work matey, as only certain headunits will accept CDC's. the cable may be long enough but if not, just extend it using spare bits of wire as long as the solder joints are good and clean you shouldnt have any problems.
as for the location, you can pretty much choose where you want to put it. i know the saloon has it hidden behind the o/s cover in the boot. IIRC the estate has it just sat and fixed inside the boot.
hope this helps a bit.
rob
Saxo, corsa, clit drivers. Before starting on a journey, attach a lit sparkler to the antenna of your car. you drive the thigs like dodgems. for the love of god MAKE IT LOOK THE PART!
RobC_NE
  • North East
« Reply #2 on: 03 July 2008, 00:56:32 »
This image may help. CDC is arrowed.
MutantCav
  • Gainsborough
« Reply #3 on: 05 July 2008, 21:30:15 »
I know the 804 will work with the CDC as it always comes with it in the earlier model elites...including the one I just got...will have to have a look at the wiring loom and see where it goes :)
