Author Topic: Thanks MDTM  (Read 3477 times)
Thanks MDTM
« on: 09 February 2008, 21:46:55 »
For spending time cleaning up my handbrake so I can get it MOT'd.
A very pleasant day (until I arrived home to a PM box full of 'the oof server is bust'), and once again, I learnt lots :y
Once again, thanks :D
PS, was I supposed to let the rear pads bed in ::) ?
Re: Thanks MDTM
« Reply #1 on: 09 February 2008, 21:52:23 »
And its quite bizzare feeling when someone else Tech2's your car  :o
Still, you could have cleared the DTC from the engine ecu you caused by using improper start procedure ;D
Re: Thanks MDTM
« Reply #2 on: 09 February 2008, 22:00:06 »
Speaking of Tech2 i could do with a plug in tommorow...  ;)
Re: Thanks MDTM
« Reply #3 on: 10 February 2008, 11:40:16 »
Lets wait for the results on the handbrake test....
And when he does the test make sure teh auto box is in N.....I have seen it done in D which gives a very false reading!
Re: Thanks MDTM
« Reply #4 on: 10 February 2008, 17:45:52 »
Well, you proved it will lock up at 30mph, so cant see there being a problem...
familyman
  • Sittingbourne, Kent
Re: Thanks MDTM
« Reply #5 on: 10 February 2008, 19:49:37 »
If she'll lock the back wheels at 30 she should walk the roller test. My 'miggy is 1800 kgs so only needed 288 kgs of effort to pass.  It only has to be 16% of weight of car on dual circuit brakes.
Okay who's just hit thier calculator button the keyboard to work out the effort on their 'miggy! ;D ;D
You came in that, your braver than i thought
Re: Thanks MDTM
« Reply #6 on: 11 February 2008, 10:45:54 »
Its back in for retest as we speak.
 [smiley=lolk.gif]
Re: Thanks MDTM
« Reply #7 on: 11 February 2008, 10:55:22 »
 [smiley=lolk.gif]
If it fails, ask him if you can apply the handbrake!
    • 530D M Sport, 330i Coupe
Re: Thanks MDTM
« Reply #8 on: 11 February 2008, 10:58:23 »
Just out of interest, how many clicks should the vehicle hold on for an MOT?
Got a feeling I need to adjust mine a bit.
Re: Thanks MDTM
« Reply #9 on: 11 February 2008, 11:00:01 »
 [smiley=lolk.gif]
I've had to leave it there, he couldn't do while-you-wait :(
Re: Thanks MDTM
« Reply #10 on: 11 February 2008, 11:10:57 »
On an Omega setup the ideal is about 6 clicks......there is no real specific pass fail point but, clearly if the lever is pointing vertical then it cant be operated effectivly from the drivers set!
Re: Thanks MDTM
« Reply #11 on: 11 February 2008, 11:17:03 »
Not that youve ever seen any like that  ::)
Re: Thanks MDTM
« Reply #12 on: 11 February 2008, 11:19:05 »
Not seen Tunnie's new estate then  :-X
Re: Thanks MDTM
« Reply #13 on: 11 February 2008, 11:19:44 »
Mine was fine until I let someone else move the car.. pulled it up so far I nearly had to get in the back seat to release it, think they may have stretched the cable!
« Last Edit: 11 February 2008, 11:19:57 by VXL_V6 »
Re: Thanks MDTM
« Reply #14 on: 11 February 2008, 11:20:36 »
not remember mine from a few weeks ago, pull it on fully and it lifts the cubby hole lid ;D
