Author Topic: MOT help for Mondeo  (Read 1539 times)
razzo
  • Crapital
    • 97 3.0 Elite
MOT help for Mondeo
« on: 11 February 2008, 22:38:16 »
Not mine but mums failed on emissions, is a 99 24v 43000 miles & FSH
                                       Spec                         Value
Fast idle                       2500-3000
Fast idle CO vol%         0.00 - 0.20                    3.57
Fast idle Hc vol ppm          0- 200                       141
Lambda                      1.030-0.970                   0.890
He recomended using a bottle of forte in a full tank & run it for 20 -30 miles tested today &
Fast idle CO vol%         0.00 - 0.30                    5.54
Fast idle Hc vol ppm          0- 200                      1705
Lambda                      1.030-0.970                   0.846
any advice as its a bit out of my league & i don't want to see her get ripped off  :(
Dazzler
  • Haverhill, Suffolk
Re: MOT help for Mondeo
« Reply #1 on: 11 February 2008, 22:40:25 »
temp sender for the ECU :-/
lee4206
  • southampton
  • Mot Tester
    • 2000 3.0l manual MV6
« Reply #2 on: 11 February 2008, 22:42:00 »
The fact that the lambda is low and the co is high usually points to lambda sensor fault worth getting that checked first.
lee
« Reply #3 on: 11 February 2008, 23:15:21 »
lee
Does a Lambda fault cause missing that does not show as a fault?
« Reply #4 on: 11 February 2008, 23:23:55 »
Looks like that's running rather rich. I'd agree temperature sensor is a real possibility. It could still be running with warmup enrichment.
Any fault codes? Would be worth getting them read.
The very high HC level on the 2nd one indicates a possible misfire but could also be due to the very rich mixture.
