Pages: 1 2 [3] 4 5 6 7 8 9 10   Go Down
Author Topic: Dash Lights  (Read 25458 times)
0 Members and 4 Guests are viewing this topic.
Ratty
  • Coventry
    • '99 2.5 CDX Mini-FL Est
Re: Dash Lights
« Reply #30 on: 01 September 2009, 10:32:38 »
any idea what his username is Robert?
John
LFF64
  • HADDENHAM BUCKS
    • 64 insignia CT Nav 4x4
Re: Dash Lights
« Reply #31 on: 01 September 2009, 10:36:58 »
I have just been and taken mine out the numbers  I  can see on it are
90460591
PA6-GF30
ETN 5312
And a yellow sticker with HE on
Ratty
  • Coventry
Re: Dash Lights
« Reply #32 on: 01 September 2009, 10:43:25 »
I'm assuming the HE is the Ident.
My Miggy seems to be a not-too-common build, it was registered march 99, so pretty much just before the facelift was released mine had/has the traffic master installed and had a non bose CCRT700 Radio dunno if that lot has anything to do with this problem but it might help those in the know to identify and help me.
would it help if i put my chassis number on here? or would that not be advisable?
John
I_want_an_Omega
Re: Dash Lights
« Reply #33 on: 01 September 2009, 10:45:39 »
Omegaspareparts
Omega Spare Parts Call 0770 6495877
Ratty
  • Coventry
Re: Dash Lights
« Reply #34 on: 01 September 2009, 10:46:52 »
cheers Mate, will give 'em a shout :)
John
LFF64
  • HADDENHAM BUCKS
Re: Dash Lights
« Reply #35 on: 01 September 2009, 11:07:30 »
have you tried the old switch back in and see if the lights work with that  :question
Ratty
  • Coventry
Re: Dash Lights
« Reply #36 on: 01 September 2009, 11:11:41 »
yes and they don't, I may have broke it when I took it apart to find the original fault after I put the replacement switch in, although I didn't really do anything inside the switch just pulled it apart and had a look then reassembled it, but no, they don't work with the replacement switch or the original one :(
John
Ratty
  • Coventry
Re: Dash Lights
« Reply #37 on: 01 September 2009, 11:13:23 »
Omegaspareparts
 gave them a call, they don't have one there but he knows of an elite (he says that some elites didn't hava HIDs) being broke and will check for me and let me know.
« Last Edit: 01 September 2009, 11:13:46 by ratsalad »
John
I_want_an_Omega
Re: Dash Lights
« Reply #38 on: 01 September 2009, 11:37:51 »
He is right - BUT, Elites from 98 MY onwards did have HID's, so that means that it must be a pre '97 Elite - which is where my headlight came from.  :(
Ratty
  • Coventry
Re: Dash Lights
« Reply #39 on: 01 September 2009, 11:43:53 »
:( so I won't hold my breath there then :(
John
I_want_an_Omega
Re: Dash Lights
« Reply #40 on: 01 September 2009, 12:31:35 »
Nope.
This has to be something really really silly like a broken wire somewhere.
What else have you done to the car recently?
Pin 58d supplies the dimmed instrument panel feed to the lights. You could try removing the light switch and then (very carefully and via a fuse) feed 12v into that pin (which should cause the panel lights to come on.
Depends how comfortable you are with electrics I guess?  :'(
Welung666
Re: Dash Lights
« Reply #41 on: 01 September 2009, 12:34:02 »
Ratty, if you fancy a trawl over to here (Dudley) I'll get my meter out and have a look for you ;) :y
Ratty
  • Coventry
Re: Dash Lights
« Reply #42 on: 01 September 2009, 12:37:07 »
only things that have been done that would affect the lighting is changed all the climate bulbs and fitted an after market sony Head unit, which is currently out to eliminate that being the cause. and changed the light switch.
I'm ok with electrics usually providing the circuit is fused but this has stumped me completely.
« Last Edit: 01 September 2009, 12:40:22 by ratsalad »
John
Ratty
  • Coventry
Re: Dash Lights
« Reply #43 on: 01 September 2009, 12:38:25 »
Cheers mate, I may well do that, it's a bit of a trek for me atm but considering that I've spent about £60 - £70 on this and still not cured it...
« Last Edit: 01 September 2009, 12:39:50 by ratsalad »
John
I_want_an_Omega
Re: Dash Lights
« Reply #44 on: 01 September 2009, 12:39:58 »
Try disconnecting the climate panel and see what happens.
Were the bulbs replaced with LEDs possibly?
Pages: 1 2 [3] 4 5 6 7 8 9 10   Go Up
