Author Topic: Bose amplifier removal.  (Read 2177 times)
  • Auckland
    • Mazda MPV
« on: 03 February 2010, 20:37:13 »
Has anybody done this recently?
I seem to be making the 500 mile round trip to London on a weekly basis at the moment, the CCR2006 + Bose is certainly loud enough but 4 cd's get repetitive and I miss my Blaupunkt DAB/MP3 head unit.
I have been advised not to try driving the Bose amplifier from the my Blaupunkt head unit so I have bought some used 4 Ohm Omega speakers to suit the Blaupunkt. I want to be able to return everything to factory so I intend to link out the Bose amplifier at the plug in the boot.
Has anyone got any photos of the plug or the bose amplifier?
I had a look last weekend and it seems that the Bose shelf is fixed with screws from above the shelf & I will need to pull the seats out to get the fibre shelf out before I can even look at the Bose amp wiring >:(
Re: Bose amplifier removal.
« Reply #1 on: 03 February 2010, 20:47:58 »
looping amp out *much* easier as drivers kick panel ;) - all the speaker wires go through this, towards amp, then feed back from amp via this connection
  • Auckland
    • Mazda MPV
« Reply #2 on: 03 February 2010, 20:57:18 »
Excellent. You're a star  :y
I don't suppose there are any wiring diagrams/cable colours/pin outs available?
« Reply #3 on: 04 February 2010, 08:25:56 »
Andy, the easiest thing to do is get the body loom off a pre-facelfit car without bose from the drivers kick panel....on the pre-facelift, this connector was still present as they had boot located cd changers (you cna cut the CD changer section off which will yeild a large connector with a load of loopbacks)..
As the sourced connector is off a non bose, the loopbacks are present for the speakers.
You need need to do something about the bose speakers being 2ohms sadly...
« Reply #4 on: 04 February 2010, 21:34:12 »
Does aerial amp remote switch on go through that connector on facelifts?
« Reply #5 on: 05 February 2010, 10:48:12 »
No, it runs either down the drivers side (estates) via its own small connector (which is part of the aerial connector assembly) or down the passenger side on saloons
  • Auckland
    • Mazda MPV
« Reply #6 on: 06 February 2010, 10:26:33 »
Thanks for the reply. Got back early this morning after another trip up to London & haven't fully woken up yet so apologies if I am being a bit slow...
When I first read your reply I thought you were saying that I couldn't do as The Boy had recommended but that I needed to change the loom for a pre-facelift.
Reading it again I am hoping that you are saying that I can get a plug out of a scrap car which will enable me to unplug the Bose amp at a connection behind the kick panel and use the plug to bridge the speaker connections. :y
I already have some 4 Ohm speakers from a non Bose facelift ready to fit in the doors.
