Author Topic: Just got myself a 2.5TD 2000 Omega.....  (Read 2765 times)
Arrolman
  • Renfrew,Scotland
« on: 15 February 2008, 17:32:46 »
Hi all,
Not been around here in a long while, finally decided to get another Omega, TD this time, X-reg. GLS model but means less to go wrong lol. What is the Timing belt change intervals on the TD? Its at 70,000 the now
Cheers,
Iain
« Last Edit: 15 February 2008, 17:33:25 by Arrolman »
Looking to win the lottery..........
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
Re: Just got myself a 2.5TD 2000 Omega.....
« Reply #1 on: 15 February 2008, 17:40:55 »
All Vauxhall are 40,000 miles or 4 years whichever comes first :y
Bo Bo
  • Coventry
« Reply #2 on: 15 February 2008, 17:42:26 »
Congrats on your purchase  :y
Arrolman
  • Renfrew,Scotland
« Reply #3 on: 15 February 2008, 17:48:33 »
Cheers,
Any idea where to get the timing belt kit from? Can't find one anywhere online so far :-/
« Last Edit: 15 February 2008, 17:48:54 by Arrolman »
bob.dent
  • Hertfordshire
  • Drives better than an Omega
    • Mondeo 2.0TDCI Estate
« Reply #4 on: 15 February 2008, 18:02:31 »
Cheers,
Congrats on the new purchase. :y
Autovaux do the kits online, here's the link:-
http://www.autovaux.co.uk/LoadPortal.aspx?cnum=104&tabid=5&vnum=141
« Reply #5 on: 15 February 2008, 18:32:48 »
Noone noticed you said TD.....
You have a Chain (normally for life iirc)
NO belt to change  :y
« Reply #6 on: 15 February 2008, 19:06:02 »
No belt on that heap of an engine ::)
I have a TD, and if I can give you 1 piece of advice:
[size=16]CHANGE THE OIL EVERY 3k MAX[/size]
No messing.
The timing chain is lubricated by the engine oil, obviously.  Diesels use the engine oil to carry away particulates caused by the diesel combustion process (thats why diesel oil changes are more frequent, forgetting marketing BS).  This makes the oil 'gritty' which accelerates wear on the chains and spockets.  Officially, to change the chains and spockets on this engine is a cylinder head off and sump off (later probably means engine removal from car), so not a job you want to do.  When the chains wear, they tend to jump a tooth on the spockets.  This also (officially) is a head and sump off job.
I know BMW raised the service interval from 4.5k to 7.5k, but this was for marketing. Even 4.5k is too long for this engine.  If they car has not had recent 3k oil changes, do some 1k oil changes for a while, then back up to 3k.
Longer life oil will not help, as the oil needs changing due to the particulates, rather than oil breakdown.
Please, please, please heed my advice.
(Vx semi synth is around £32 for 20l on trade club, and the filter (yours will be cheaper later type) is around £6 on TC.  You will need a 36mm socket for the filter as well.  Also, then sump plug is prone to stripping, if yours is M12 one, double check with dealer on torque setting - I think its around 20Nm.
Arrolman
  • Renfrew,Scotland
« Reply #7 on: 15 February 2008, 19:29:12 »
Hi,
Thanks for the advice, my dad works for Vauxhall so gets everything cheap anyway, first thing that will be done is an oil change, where is the fuel filter located? I like to change all the service items when I get a new car, means I know whats been done
Cheers,
Iain
« Last Edit: 15 February 2008, 19:29:53 by Arrolman »
« Reply #8 on: 15 February 2008, 19:47:15 »
Hi,
Cheers,
Iain
Fuel filter is fitted in engine bay, between airbox and brake servo. Can't miss it, looks like spin on oil filter.
As its new to you, and as you'll probably be doing coolant, whip out waterpump and check it still has its impellers (they have a habit of shedding them).
« Reply #9 on: 15 February 2008, 19:48:25 »
Oh, and to add cruise to your GLS, just buy a cruise stalk ;) (TD takes a different cruise stalk to other Omegas, so get the right one).
Arrolman
  • Renfrew,Scotland
« Reply #10 on: 15 February 2008, 20:09:40 »
Had heard that about the stalk, something else to add to the shopping list!
Cheers,
Iain
Arrolman
  • Renfrew,Scotland
« Reply #11 on: 17 February 2008, 16:10:34 »
Does anyone know where to get teh cruise control stalk for a TD Omega? Can't seem to find a TD specific one?
Cheers,
Iain
« Reply #12 on: 17 February 2008, 18:08:26 »
Cheers,
Iain
dealer. dont mess with 2nd hand or pattern, they don't last. petrol one is around £30, i guess td similarish
Pitchfork
  • Tadley (near Basingrad)
  • Barndances & Morris
« Reply #13 on: 17 February 2008, 19:39:07 »
Cheers,
Iain
Part No is 9181012
Circa £40 retail
IW
Arrolman
  • Renfrew,Scotland
« Reply #14 on: 19 February 2008, 17:45:20 »
Cheers for the part number. While ordering the bits for an oil change I got asked whether my Omega had a metal or paper oil filter? Apparantly the later type was either metal or paper, anyone know what mine is? I've pre ordered a paper one but its just a guess till I get the car on friday
Cheers,
Iain
