Can I straight swap a CCR2006 for a CDR2005?
Started by Neil_MV6, 26 February 2011, 10:27:07
Neil_MV6
I would like a front loading single CD player instead of my 4-CD multi-changer (with magazine stuck in).
If I bought a CDR 2005, could I do a simple straight swap?
Cheers
Neil
Dave DND
Radio & Decoding Technician
www.dndservices.co.uk
#4
Dave - I just followed your link and found all this code at the top of your web page.
QuoteINVALID SQL: 145 : Table './web110@002dshop/xcart_sessions_data' is marked as crashed and should be repaired
SQL QUERY FAILURE:SELECT COUNT(*) FROM xcart_sessions_data WHERE sessid='cd2f3775e8b00469985dfdb8fbbbb87e'
SQL QUERY FAILURE:SELECT sessid FROM xcart_sessions_data WHERE expiry < '1298729538'
SQL QUERY FAILURE:SELECT * FROM xcart_sessions_data WHERE sessid='cd2f3775e8b00469985dfdb8fbbbb87e'
SQL QUERY FAILURE:REPLACE INTO xcart_sessions_data (sessid, start, expiry, data) VALUES('cd2f3775e8b00469985dfdb8fbbbb87e', '1298729538', '1298733138', 'a:0:{}')
SQL QUERY FAILURE:UPDATE xcart_sessions_data SET data='a:6:{s:17:\"_saved_session_fg\";s:32:\"c466d40cf983aa5d78b80b5f334ccd47\";s:11:\"editor_mode\";s:0:\"\";s:8:\"is_robot\";s:1:\"N\";s:5:\"robot\";s:0:\"\";s:11:\"is_location\";s:0:\"\";s:9:\"adaptives\";a:1:{s:14:\"is_first_start\";s:1:\"Y\";}}' WHERE sessid='cd2f3775e8b00469985dfdb8fbbbb87e'
SQL QUERY FAILURE:UPDATE xcart_sessions_data SET data='a:7:{s:17:\"_saved_session_fg\";s:32:\"c466d40cf983aa5d78b80b5f334ccd47\";s:11:\"editor_mode\";s:0:\"\";s:8:\"is_robot\";s:1:\"N\";s:5:\"robot\";s:0:\"\";s:11:\"is_location\";s:0:\"\";s:9:\"adaptives\";a:1:{s:14:\"is_first_start\";s:1:\"Y\";}s:22:\"antibot_validation_val\";a:4:{s:13:\"on_contact_us\";a:2:{s:4:\"code\";s:5:\"98619\";s:4:\"used\";s:1:\"N\";}s:15:\"on_registration\";a:2:{s:4:\"code\";s:5:\"65369\";s:4:\"used\";s:1:\"N\";}s:8:\"on_login\";a:2:{s:4:\"code\";s:5:\"35856\";s:4:\"used\";s:1:\"N\";}s:10:\"on_reviews\";a:2:{s:4:\"code\";s:5:\"23576\";s:4:\"used\";s:1:\"N\";}}}' WHERE sessid='cd2f3775e8b00469985dfdb8fbbbb87e'
SQL QUERY FAILURE:UPDATE xcart_sessions_data SET data='a:22:{s:17:\"_saved_session_fg\";s:32:\"c466d40cf983aa5d78b80b5f334ccd47\";s:11:\"editor_mode\";s:0:\"\";s:8:\"is_robot\";s:1:\"N\";s:5:\"robot\";s:0:\"\";s:11:\"is_location\";s:0:\"\";s:9:\"adaptives\";a:1:{s:14:\"is_first_start\";s:1:\"Y\";}s:22:\"antibot_validation_val\";a:4:{s:13:\"on_contact_us\";a:2:{s:4:\"code\";s:5:\"98619\";s:4:\"used\";s:1:\"N\";}s:15:\"on_registration\";a:2:{s:4:\"code\";s:5:\"65369\";s:4:\"used\";s:1:\"N\";}s:8:\"on_login\";a:2:{s:4:\"code\";s:5:\"35856\";s:4:\"used\";s:1:\"N\";}s:10:\"on_reviews\";a:2:{s:4:\"code\";s:5:\"23576\";s:4:\"used\";s:1:\"N\";}}s:11:\"logout_user\";s:0:\"\";s:26:\"session_failed_transaction\";s:0:\"\";s:16:\"add_to_cart_time\";s:0:\"\";s:17:\"always_allow_shop\";s:0:\"\";s:11:\"search_data\";s:0:\"\";s:4:\"wlid\";s:0:\"\";s:10:\"js_enabled\";s:1:\"Y\";s:11:\"top_message\";s:0:\"\";s:15:\"referer_session\";s:59:\"http://www.omegaowners.com/forum/YaBB.pl?num=1273965375/all\";s:5:\"login\";s:0:\"\";s:10:\"login_type\";s:0:\"\";s:11:\"identifiers\";a:0:{}s:6:\"logged\";s:0:\"\";s:14:\"remember_login\";b:0;s:13:\"remember_data\";s:0:\"\";}' WHERE sessid='cd2f3775e8b00469985dfdb8fbbbb87e'
Oops. I hope it is just a cosmetic failure and not an SQL injection attack..............
Dave DND
Just had a server go down
I`m on the case, but thanks for the heads up anyway
