Author Topic: Audio display query  (Read 2396 times)
MV6Matt
  • London
    • No car since 2022....
Audio display query
« on: 04 April 2011, 07:28:59 »
Since changing to a new aftermarket Head Unit  the display on the dash loses the date whenever the radio is turned on - no surprises there that will happen of course with such a change.
My question is:- is there any way that you can bypass this function so that the date stays up all the time (whether radio on or not)?
Anyone know of a way?
Matthew :y
(thanks Ian)
    • E250 Est / Elroq
Re: Audio display query
« Reply #1 on: 04 April 2011, 07:51:36 »
yes, you can cut a wire behind the mid.
or tech2 can reprogram to say no radio present.
MV6Matt
  • London
« Reply #2 on: 04 April 2011, 09:15:52 »
Cut rather than disconnect? (is diconnecting poss or is it part of a plug?) And which one?  :-/
As a person with zero knowledge of what's what behind the head unit  :-[ (and it all looks like spagetti junction anyway) anyone know? :-[
Matthew
(thanks Ian)
« Reply #3 on: 04 April 2011, 09:54:32 »
Matthew
Hmmm, in that case, maybe reprogramming is a safer option ;D
« Reply #4 on: 04 April 2011, 10:06:15 »
Since changing to a new aftermarket Head Unit  the display on the dash loses the date whenever the radio is turned on -  .....
Same happens with OE head units in both my Astra & Omega .......  :-? :-?
« Reply #5 on: 04 April 2011, 10:11:12 »
Yes, because the Radio information appears there instead. With non OE radio, this just blanks.
MV6Matt
  • London
« Reply #6 on: 04 April 2011, 10:32:35 »
Matthew
Yes I'm inclined to agree - but if I can be directed to the right one that should be ok too.
So is a cut or a disconnect and which wire?  :(
(thanks Ian)
« Reply #7 on: 04 April 2011, 11:18:05 »
Sorry ....... I was having a blonde moment!  ::)
