Telematics loom
Started by feeutfo, 27 April 2011, 22:36:48
QuoteAnyone got a picture of the Carin bracket in the correct location?
Will have a nose at the parkpilot location tomorrow.
No, but you can see where it fits above NSR shock - it uses to holes at back (covered with plastic caps holding carpet in place...
Sounds a promising location.....
More questions!
1) Do you have / will you have a phone kit installed as well?
2) If not do you want to retain the option of having one?
3) TB - If CG says yes to either above can you obtain another of your impedance matching circuits?
4) What's this HK Ipod adapter thingy wotsit? Is it a modulator - any install diagrams available?
5) Anyone got some old prefacelift CD changer looms so I rob the shielded cable off them?  ::) ;D
Cheers
QuoteMore questions!
Cheers
3) I'll see if my best mate Rik kept the artwork for the PCB, if so, its an easy build.
4) I think that just plugs in the aerial (its a wired FM Modulator)
Cheers
IIRC that is correct... I helped fit one a couple of years ago
Cheers
That said, it will need power, and a 'radio on' signal, so the custom telematics loom could be an ideal place to pick it up...
Cheers
Yes... ISTR that I took the power connections from the H/F Kit Pre-wiring :-/ It was at the first EA meet on Humbucker's car
Cheers
1) not currently. Plug is there though.
2) if possiible then yes please. (didnt think that was possible) iphone4 though, so may not be worth the bother?
3)-
4) needs a live feed, and can be either modulator over fm broad cast, or plugged directly into fm headunit input, afaik. Not sure exct model, but like this one. http://www.amazon.co.uk/Harman-kardon-Drive-vehicle-built/dp/B000DZ834W
5)-
Iphone over bluetooth works fine, its just the god awful voice dialling.  Try it just on the phone, and see how bad it is ;D
QuoteIphone over bluetooth works fine, its just the god awful voice dialling.  Try it just on the phone, and see how bad it is ;D
Oh break me i'll never use that, its 'dangle berries' on any phone. Normal dialing yes, voice dialing not a hope.
Even the N95 made a better job of voice dialling ;D. Apple's attempt is truely abysmal!
Which bluetooth kit? If Nokia CK7W I have a few here....  ;)
HK Hookup not a problem.
TB, any chance of getting a small number of these circuits made up?
QuoteWhich bluetooth kit? If Nokia CK7W I have a few here....  ;)
seems the best one?  :-/
seems the nest one?  :-/
for a bird ::)
for a bird ::)
'dangle berries', thought I'd got away with that.
Your too quick MrG. Surely everyone knows by now I need at least one edit per post. :-?     ;D
