Telematics loom
Started by feeutfo, 27 April 2011, 22:36:48
No problem will utilise the prewiring.
QuoteWhich bluetooth kit? If Nokia CK7W I have a few here....  ;)
seems the nest one?  :-/
for a bird ::)
'dangle berries', thought I'd got away with that.
Your too quick MrG. Surely everyone knows by now I need at least one edit per post. :-?     ;D
Only one :o ;D
for a bird ::)
You could do with a few more edits on most posts too!  ::) ::) ::) ::)
and RobG agrees!  ;D ;D ;D
I blame Jobs personally  ::)
seems the best one?  :-/
I use one of them in each of my 3 cars. Works as well as anything, tidy install as only a single, simple button, and best of all, dirt cheap 2nd hand ;D
Sounds good, let's do that then. If that's ok with Andy?  :y
OK, No problem, telemute / 06-109B now modified with correct plug for CK-7W and +12V, +12V switched and 0V tails added after fuses to run HK device.
TB, do you use the 'matching transformers' on your carkit's connected to Bose? I know your supposed to and all my cars use them but I only have some 'plain telemute leads here.
Also considering where to add impedance matching circuit in the loom, presently favouring fitting at telematics (boot) end which will need switched 12V feed  ::).
Haven't used the transformers in the elite (built in on the mv6), but that lacks telematics.
I think autoleads are so far out of touch with these cars, you cant take their recommendations.
OK, have made a little progress with this loom now:-
Telematics 32 Way connector completed:
Cable sleeving added to keep loom neat in boot area.
36Way ISO, first connection made... waiting on obtaining suitable cabling to continue:
To run the bluetooth car kit and Ipod Modulator a Telemute / Autoloeads cable was modified by cutting off old style Nokia power connector and replacing with new style for CK-7W etc kits. Have also added +12V, Ignition switched +12V and 0V after the fuses for Harmon Kardon Ipod modulator power connection.
Is MIC wire missing?
Actually, that raises a good point - MIC sharing between telematics and Nokia?  In the MV6 I used seperate MICs as the simple/easy solution  :-/
QuoteIs MIC wire missing?
Yes, Mic wire missing, telematics mic input will plug into telemute lead and telematics mic will plug into standard connector at courtesy lamp end (well it worked on mine!)
Nokia will use standard HFM-8 Mic..... at least it will if CG can obtain one as I can't find one despite having three CK-7W's here!
The telemtaics MIC is a powered / amplified device IIRC
Yup, I reckon Nokia one must be as well - as I used the built in mic for the nokia kit in the Elite.
Dont think I have a spare mic...  ...but egay have then cheap enough
Wow, looking good. :y
If anyone has a link to the mic needed  :-[  i'll get it....?  :)
Aye, either one of those or the earlier HFM-8 will be fine. Don't get one just yet though, give me a chance to have a sift through my various boxes of junk quality spares.  ;D
