VIN Input in TIS 2000
Started by wesagog, 16 May 2011, 14:35:29
wesagog
Dears,
My VIN is: W0L000025T1004507 (Omega B)
When I input this vin in TIS2000 I get eror (E714)...
Any help please?
Why are you trying to enter vin into tis  :-/
wesagog
I want to get the wiring harness in order to find the connectors (male-female) between the outside harness and the inside...
I think I have a problem (bad connection or loose) so I want to check and clean all the connectors. I found one of them which located under the rear set very rusty and lose.
If you can help me please.
Just give it rough details, it doesnt need your VIN  :y
ive never entered one and access all I need :y
QuoteI want to get the wiring harness in order to find the connectors (male-female) between the outside harness and the inside...
Don't bother with VIN, just enter Model (Omega) and Year (2002 or 2003 - even if yours is earlier, as those are the only 2 years with electronics wiring diagrams)
hazpaker
just imput this vin into tis 2000 and got omega B 1996 :), double check you are keying it in correctly :y
