Aftermarket HU compatibility
Started by Goodwood, 15 May 2011, 18:08:22
Goodwood
Does anyone know if a Sony CDX GT300 can connect up to the TID on a 95 Omega. I assume if it does i need some sort of adapter?
Dave DND
There used to be an interface around many moons ago that ran a display output from the CD changer port on the Sony models
However, if you do manage to locate one (they were well over £100) its worth checking that the CD changer protocol will still work, as I have a gut feeling that it may not on such a recent model - steering controls should not present a problem though.
Radio & Decoding Technician
www.dndservices.co.uk
Goodwood
#2
Thanks for your help, i will have a look for the Sony adapter then!
Goodwood
Ok, head unit fitted, but I seem to have lost the permenant live, any suggestions?
You normally need to swap perm and switched live on after marked headunits destined for Vauxhalls, many stereos have bullet connectons on the red and yellow wires to allow this easily.
Goodwood
So thats why they are on bullet connectors?!! ;D
Swapped the wires and all is sorted. Thanks for your help! :y
