key fob
Started by fiend61, 22 May 2011, 08:37:16
fiend61
hi all
quick question  ;)
if i buy a new 3 button fob off the bay of e is just a case of putting my blade and transponder/chip into it then syncing it with the car, or should it work straight away  :y
TIA
[edit]forgot to mention that the pcb looks to be fubared so new key would have to have pcb aswell  :([/edit]
No, needs tech2 programming to work with your car.
Wouldnt be very secure otherwise ;)
3 parts to a key
blade for doors / ignition
chip / transponder for immobiliser
remote gubbins for central locking.
you can get 2 out the 3 by swapping bits over.
fiend61
ahh thanks jimbob  :y
next question then is there anyone near york weekends or staines during week who has a tech2  ;) and what do i need carpass ?
tia
Quote.... and what do i need carpass ?
tia
yes  :y
fiend61
andy
is the car pass number the same as the alarm code?? had a look through the paperwork and found radio code and alarm code ?
i know the car pass is credit card size but how many digits are there normally because have several numbers written down on different pieces of paperwork  :( and never heard of alarm code  :-/
Quoteandy
I think it's the immobiliser code  :-/
I just went to look at mine, but can't find the bl00dy thing  :'(
Alarm code = Immobiliser pin = Car Pin
I'm in Brackley if you pass that on way to York/Stains - http://theboy.omegaowners.com
fiend61
#7
cheers TB
ummm whereabouts is Brackley  :-[
or i could post it to you  ;)
Quotecheers TB
When you thinking? Not around most evenings this week?
fiend61
Quotecheers TB
err do you mean for me to pop round or for me to post key and car pass too you ???? :-/
Quotecheers TB
car and fob both have to be present for it to work  :y
fiend61
Quotecar and fob both have to be present for it to work
hmmmm that makes sense  :-[
plus like to see postman delivering the mig  ;D ;D
TB give me some dates/times when you could do it  ;)
cheers
I might struggle evenings this week, but am around at weekend.  Bank Holiday, I'm at the Bucks meet if that helps?
Martin_1962
Quotehi all
quick question  ;)
TIA
Why is it FUBAR then?
Is it actually broken or are the switches knackered
fiend61
martin the one i am sending to you for repair has no battery holder, not sure if switches work either , i got it in bits from previous owner  :'(
i am buying another so i have 2 spares  ;)
