Author Topic: TID Removal and replacing  (Read 2372 times)
Goodwood
  • Warboys
« on: 14 May 2011, 15:58:53 »
If i remove the TID from my dashboard, can i replace the clocks without the TID, and still use the car, without any detrimental effects(warning light etc)
The theory being i can then fix it at my leisure, and replace.
On a secondary note does anyone have, or know of where i can source a known good replacement? Early type(Yellow & Black plugs) i think?
Re: TID Removal and replacing
« Reply #1 on: 14 May 2011, 19:19:30 »
yes
Goodwood
  • Warboys
« Reply #2 on: 19 May 2011, 12:28:32 »
Yes i can leave it out or yes you know where i may be able to source a replacement?
« Reply #3 on: 19 May 2011, 12:42:52 »
Yes, you can leave it out. Early replacements in full working order are scarce
« Reply #4 on: 19 May 2011, 12:45:53 »
Given your taking it out, it must be annoying you, so why not chance a repair?
http://members.home.nl/opeltje/mid%20reparatie.htm
Goodwood
  • Warboys
« Reply #5 on: 19 May 2011, 13:15:20 »
The repair was my intention, i just wanted to know if i could still use the car without any detrimental effects, or had to lay it up while i repaired it.
Thanks for your help
Goodwood
  • Warboys
« Reply #6 on: 27 May 2011, 15:18:40 »
Ok,
Removed the TID/MID did exactly as the guide suggested. Unfortunatly it seems to have had no little/a negative effect.
So where can i get another(yellow & Black plug) TID?
Page created in 0.009 seconds with 17 queries.
