Author Topic: Central locking and key question  (Read 2573 times)
51M0N
  • Hull
« on: 26 May 2011, 16:23:21 »
This has been bothering me for a while now.
I have 2 keys to operate my Omega.
The old early round key for the doors. (I have to manually put this in the lock)
And a later Horse shoe type for the ignition barrel.
This was how I got it so I don't know what the hell happened.
The question is, I have several blank keys and fobs with a chip in. is there ANY way I can get these programmed so I can unlock the car remotely. I'm not bothered about needing a different key for the ignition. I'm just fed up of having to put the key in the door.
Thanks in advance
Re: Central locking and key question
« Reply #1 on: 26 May 2011, 16:55:43 »
Yes, any of us with a Tech2 can pair them provided:
1) You have the car pass for the vehicle
2) The fob remotes are of the right type (there are several different types of transmitter).
Best to open up the working and "spare" fobs and see if the PCB is identical first.
« Reply #2 on: 26 May 2011, 16:59:17 »
Ahh, actually, for a 1995 car it's possible I'm talking out of my 'arris. :-/
« Reply #3 on: 26 May 2011, 17:47:53 »
yes...prob infra red central locking, and tech 1 required.
51M0N
  • Hull
« Reply #4 on: 26 May 2011, 17:56:12 »
I know my first omega on the same year was infared because the pickup was near the sunroof motor.
Whats this car pass? heard it before but unsure?
Stallion
  • Romford
    • 3.2 Irmscher Elite
« Reply #5 on: 26 May 2011, 18:25:25 »
its a small card, that should be in the booklet wallet it contains your car stereo code/details, VIN, key code/type, other details etc..  :y
« Last Edit: 26 May 2011, 18:26:08 by Stallion »
« Reply #6 on: 26 May 2011, 20:23:18 »
Tech2 cannot do IR style locking.
51M0N
  • Hull
« Reply #7 on: 26 May 2011, 20:25:58 »
found a tiny boom that was it. no card :(
Clarkey
  • Ireland
    • 01 3.2 Auto Executive
« Reply #8 on: 27 May 2011, 21:39:11 »
You do need Tech 1 to prog new I.R. remote but security code is not needed IIR. Early Vectra B with seperate key fob remote could be programmed without code too.
51M0N
  • Hull
« Reply #9 on: 28 May 2011, 09:11:32 »
Its definately ir locking i have a fob with a chip in but obv its not programmed.
