Author Topic: Blowing fuse for lights (right hand side )  (Read 2769 times)
kcl
  • Finland
    • Volvo V60 D4 -14
« on: 16 June 2011, 19:27:21 »
Cant remember, which number fuse, 10 amp and in the top row, fuse for passenger side parking lights (drivers side in UK). Blown twice within two days. No work has been done, nothing changed, bulbs and wiring "seems" ok...  :( Where would you start? So far with any cars have ever had any problems with fuses for lights
Re: Blowing fuse for lights (right hand side )
« Reply #1 on: 16 June 2011, 21:15:43 »
You need to check the wiring thoroughly. There's a short somewhere :(
kcl
  • Finland
    • Volvo V60 D4 -14
« Reply #2 on: 17 June 2011, 06:23:48 »
Ok, that was my thought but still... The wiring goes through very "safe" places... What else is behind that fuse? front and rear light, anything else?
kcl
  • Finland
    • Volvo V60 D4 -14
« Reply #3 on: 20 June 2011, 10:37:23 »
Strange one... I tried to visually check all the wiring I could see, tried to find out the fault with multimeter and it all seems ok. And, the fuse hase now kept four days  :y Could it be... just a thought... The original fuse was "tired" for some reason, the replacement was faulty for some reason and now the third is ok  :-/ Yes, it is a long shot... But however, lights on and fuse still in one piece  :y Let's see how it turns out.
kcl
  • Finland
    • Volvo V60 D4 -14
« Reply #4 on: 11 July 2011, 11:15:23 »
Ok, I'm pretty sure where the fault is: it must be in the wiring going from chassis to tailgate. Does anyone know which wires go inside which rubber grommet? There are two, one on each side of tailgate and they seem so tight fit that would not take both apart "just in case".
kcl
  • Finland
    • Volvo V60 D4 -14
« Reply #5 on: 11 July 2011, 18:47:41 »
Speaking to myself :-) It was the wiring through the grommet, one thick brown wire was broken, also another, was it grey with green stripe was scratched. Anyone know which wires they are? And, the wires go through the left hand grommet, right hand one is for window washer jet  :y
sticka_v8_init
  • Reading
    • 2.5 V6 Tourer
« Reply #6 on: 11 July 2011, 20:11:35 »
Thick & brown..having a guess would say the heated rear window.
Those are my principles, if you don't like them I have others.
kcl
  • Finland
    • Volvo V60 D4 -14
« Reply #7 on: 13 July 2011, 11:46:49 »
Anyone for the wire colours...  :'(
« Reply #8 on: 13 July 2011, 11:52:24 »
black/blue ......... rear fog
black/white ....... left turn
black/green ....... right turn
grey/black ......... left tail
grey/red ............ right tail
black/yellow ....... brake lights
hope this helps  :y
kcl
  • Finland
    • Volvo V60 D4 -14
« Reply #9 on: 13 July 2011, 11:57:43 »
Thanks  :y So it leaves that the brown one is ground/negative.
« Reply #10 on: 13 July 2011, 12:00:30 »
Yes! You spotted my deliberate omission!   ::)  ::)  ::)
kcl
  • Finland
    • Volvo V60 D4 -14
« Reply #11 on: 13 July 2011, 12:02:34 »
Well, probably the very first time I've ever spotted anything obvious   ;D ;D ;D
Page created in 0.009 seconds with 17 queries.
