Towbar electrics help
Started by BlueBridge, 19 July 2011, 18:34:09
blackviper90210
Although not positive, this sounds like a split charge relay...  :-/
AKA - Mr Bracket
BlueBridge
Jon
Sorry but I get this message ......
Error (403)
It seems you don't belong here! You should probably try logging in?
You can also check out our FAQ or forums and maybe you'll find what you were looking for. Or maybe you should try heading home.
blackviper90210
Can't see your pictures, did you put them in the public folder?
AKA - Mr Bracket
Both links don't work as I can't log in .. :)
Don't think its a split charge as the OP is listing way too many wires .... split charge will have 2 in - power and return and maybe 3 out max IMHO .. and the inputs should be fairly beefy gauge ....
BlueBridge
Jon
I reckon it could be a by-pass relay .....  :-/ :-/
Quotetry this
Same as before  :'(
Quotetry this
still asking for a login
BlueBridge
#24
deleted
Jon
blackviper90210
Need to resize me thinks!!  :y
AKA - Mr Bracket
far to large to see anything properly .... sorry .. :(
EDIT .. looked at it a diffeent way .. and I still don't recognise it ....  the right hand side looks like the output as it has 7 wires... 6 + white for earth .. and 12N/ 12S cables have 7 cores. Left hand side must be inputs from the car systems ...  but quite why all the I/Cs I don't know...   :(
Although I've never seen a by-pass relay, I think I was right.
You don't need it & you can bin it.  :y
Quotefar to large to see anything properly .... sorry .. :(
Copy & save it to your own PC/lappy  ;)
or right click /view image .. :)
