Towbar electrics help
Started by BlueBridge, 19 July 2011, 18:34:09
BlueBridge
Hi, just about to wire my towbar up, I saw on here a while ago what colours connect to what, but cant find it, anybody able to tell me, Just about to start so hopefully someone can help, cheers :y
Jon
Jon
blackviper90210
Towbar colours:
Blue - Rear Fog Supply
Green - RH Flasher
White - Earth
Black - LH Side Flasher
Yellow - LH Flasher
Brown - RH Side Flasher
Red - Stop Lights
Purple - Rear Fog Lamps
Vehicle Harness:
Black/Blue - Fog Light
Black/White - Turn Signal Left
Red - +12v Permanent
Grey/Black - Tail Lamp Left
Black/Yellow - Stop Lamp
Grey/Red - Tail Lamp Right
Black/Green - Turn Signal Right
Brown - Chassis/Negative
White/Black - Reversing Lamp
HTH  :y
AKA - Mr Bracket
QuoteTowbar colours:
Green - RH Flasher
White - Earth
Yellow - LH Flasher
Red - Stop Lights
Vehicle Harness:
HTH  :y
Assuming using 12N & 12S sockets  ::)
BlueBridge
#3
Thanks Black Viper,
Got no purple on the tow bar colours though :-?
Jon
BlueBridge
Andy.... I am chopping them :D
Jon
QuoteAndy.... I am chopping them :D
:-/ Chopping what?  :-/
blackviper90210
Could be painful  ::) ::)
AKA - Mr Bracket
blackviper90210
The colour codes were from Witter website, which I used to get my bar installed...
AKA - Mr Bracket
QuoteThe colour codes were from Witter website, which I used to get my bar installed...
Green - RH Flasher
White - Earth
Yellow - LH Flasher
Red - Stop Lights
I suspect a mis-print then, as there are two colours for the rear fogs  ;) ;)
blackviper90210
Well spotted Andy, will go and check and put my glasses back on, lol  ;D
AKA - Mr Bracket
BlueBridge
Thanks lads, I'm chopping the wires as I havent got the socket on the towbar end.
Jon
BlueBridge
Another problem, I,ve connected the towbar wires where the previous owner had cut when removing, but they go into a circuit type board, and at the other end the colours are different, they are
brown
yellow
2 lots of grey
Blue
Black
Green
White
Red,
all of these are a much thinner wire, and also coming from this is an orange wire with an inline fuse on and another white one, which is from the original cable but not going through the circuit board.
Hope I've explained that well enough.
Or can I just not bother with this box?????
Sorry to be a thicko  :y
Jon
Jon
QuoteAnother problem, I,ve connected the towbar wires where the previous owner had cut when removing, but they go into a circuit type board, and at the other end the colours are different, they are
brown
yellow
2 lots of grey
Blue
Black
Green
White
Red,
Jon
Errr?  :-/ No!  ::)  ;) ;) ;)
Any photo's?  :y
BlueBridge
Photos coming up in a sec :y
Jon
