Towbar electrics help
Started by BlueBridge, 19 July 2011, 18:34:09
BlueBridge
Sorry about this, I have tried resizing them, but they still come up just as big, durrr, any ideas how to get them up smaller? :-[
Jon
BlueBridge
Jon
looking at that again .. I wonder if its some sort of "power amplifier" ... as the input wires are quite small in comparison to the outputs, and the large input on the left looks like a power source ???
Quotelooking at that again .. I wonder if its some sort of "power amplifier" ... as the input wires are quite small in comparison to the outputs, and the large input on the left looks like a power source ???
Which why I suspect it's a 7 way by-pass relay.  :-/
BlueBridge
QuoteTowbar colours:
Blue - Rear Fog Supply
Green - RH Flasher
White - Earth
Black - LH Side Flasher
Yellow - LH Flasher
Brown - RH Side Flasher
Red - Stop Lights
Purple - Rear Fog Lamps
Vehicle Harness:
Black/Blue - Fog Light
Black/White - Turn Signal Left
Red - +12v PermanentGrey/Black - Tail Lamp Left
Black/Yellow - Stop Lamp
Grey/Red - Tail Lamp Right
Black/Green - Turn Signal Right
Brown - Chassis/Negative
White/Black - Reversing Lamp
HTH  :y
Assuming using 12N & 12S sockets  ::)
Ha ha, your going to hate me,  cos I'm not using the sockets, where do I connect the live to?
Think I shouldn't have been so tight and got this fitted professionally.
Jon
Quote......
Do you mean that you're not using the OE socket in the boot? That's OK, you just need to make a proper connection ie NOT using Scotchlock connectors. You could chop the socket off & solder your  7 core cable to the individual wires.
Which live? If you mean for your newly discovered relay, just bin the relay. If you mean the feed for the caravan charging & fridge, then there is a larger red cable in the loom to the socket in the boot & put a fuse in under the dash.
Quote......
You might wish to use screw type cable connectors FIRST .. to make sure everything works as it should, then solder/shrink wrap once you KNOW it is right .......  just a thought  ...   :)
Quote....
Good idea.  :y :y
BlueBridge
Quote......
I'm just connecting single electrics for trailer, so does that mean I dont need to connect the thick red live?
Jon
Quote.....
Correct.
Just be aware that you pick up a live feed for the brakes (yellow/black) The feed at the OE socket is via a relay base up front under the dash. It's to extend the brake light check to your trailer - I suspect you won't want to do this  ::) so just find a feed from the back of the lights themselves.  :y :y
BlueBridge
Thanks for all your help, too dark now so I'll have a crack tomorrow.
Cheers everyone :y
Jon
