Author Topic: C/L module swap  (Read 1506 times)
RobG
    • 16 plate Mokka. Vivaro
C/L module swap
« on: 26 August 2011, 18:07:48 »
If you replace the C/L module with one with same part number is there any coding/pairing needed :question
« Last Edit: 26 August 2011, 18:08:23 by RobG »
Re: C/L module swap
« Reply #1 on: 26 August 2011, 18:11:31 »
Doubt it. ;)
I dont actually know though. ::)
RobG
Re: C/L module swap
« Reply #2 on: 26 August 2011, 19:46:09 »
Doubt it. ;)
Pointless bloody answer innit ;D
Re: C/L module swap
« Reply #3 on: 26 August 2011, 21:27:39 »
Doubt it. ;)
Maybe Albs is joining the conservatives?  ;D
Re: C/L module swap
« Reply #4 on: 26 August 2011, 21:31:04 »
Has hell frozen over ? ;)
Re: C/L module swap
« Reply #5 on: 26 August 2011, 21:57:34 »
For the Central Locking or Alarm ECU, only coding is teh key fobs.
RobG
Re: C/L module swap
« Reply #6 on: 26 August 2011, 22:02:58 »
member outside of the UK wants the C/L module and a couple of key fobs amongst other things. The fobs and module are from 2 different cars. Member says he needs the immob. code for the fobs, I thought he only needs the code for his own car to pair the fobs :-/
Re: C/L module swap
« Reply #7 on: 26 August 2011, 22:09:38 »
To program the ECU, he needs the PIN code (Immobilser on carpass) from that ECU.  Not from his ECU.
