Author Topic: oil changes by syphon not sump plug?  (Read 2772 times)
Varche
  • Online Online
  • middle of Andalucia
    • Golf Estate
« on: 25 February 2008, 12:09:46 »
Due to a number of encounters with rocks etc my sump plug is stuck in. Rather than take it out and strip the threads and be transportless till I got it helicoiled or a new sump pan, I get oil and filter changes done at a local garage where the guy syphons the hot oil out by machine.
I presume that this doesn't get all the oil out but if done regularly can't be that bad, can it?.
Anyone else use this method?
varche
theolodian
  • I need a new avatar.
Re: oil changes by syphon not sump plug?
« Reply #1 on: 25 February 2008, 12:14:29 »
varche
It's not nice, but often used on boats.
Richie London
  • heathrow
« Reply #2 on: 25 February 2008, 12:23:13 »
i do that with bottles of lager, usually through a straw,
disadvantage = lightheaded and poor balancing
advantage= job satisfaction
richie  :) :) :)
« Reply #3 on: 25 February 2008, 12:24:57 »
Machine Mart do a range of suction oil extractors.
Prob easier for a garage, no chance of a stripped thread, less messy
« Reply #4 on: 25 February 2008, 12:35:26 »
There are 2 designs of v6 sump iirc - one is easy to change, so that would be best solution to be honest...
Richie London
  • heathrow
« Reply #5 on: 25 February 2008, 12:47:38 »
try this site, maybe able to help you
« Reply #6 on: 25 February 2008, 12:48:23 »
linky?
    • 530D M Sport, 330i Coupe
« Reply #7 on: 25 February 2008, 12:49:43 »
linky?
www.omegaowners.com  :y
Richie London
  • heathrow
JesterRT
  • Stafford
« Reply #9 on: 25 February 2008, 13:38:00 »
I've attempted this before.  I got a pump (fairly cheap from eBay - similar to the Multi-Purpose Syphon and Pump Kit 8p from the link somewhere above) and spent a long time trying to get the oil out.  It's messy, the seals on the pump failed, the transfer rate was rubbish and I got pretty sick of the process quite quickly.
Ok - the pump was crap, but I'm not convinced for a moment that all the oil came out.  Nowhere near as much would come out compared to taking the plug out.
I'd try and fix the sump plug - particularly if you can change the sump without having to take the engine out.  I've got a 2.5TD which (as far as I know) required the engine out to change the sump.
It still makes me wonder what someone was thinking when making a sump softer than the bolt that goes into it.  It's got to be just money grabbing for the dealers.  I'd be happy to pay an extra quid or two for a new plug with each filter if it meant that it wouldn't strip the thread on the sump.
Anyone ever helicoiled their sump before?  How difficult's that?
« Reply #10 on: 25 February 2008, 15:19:51 »
Welcome to BMW design >:(
Marks_DTM helicoiled mine and fitted a quick drain plug.  Unfortunately I bottomed out the car at about 80mph, ripping the sump plug out.  Still, the helicoil survived, so I just put in a normal plug.
