Author Topic: Minimum pit depth for a gearbox change  (Read 1965 times)
Varche
  • middle of Andalucia
    • Golf Estate
« on: 01 March 2008, 15:02:44 »
Last year I made a temporary pit/ramp out of breeze blocks. It was great for changing the exhaust and other under the car tasks like ATF change.
I am intending changing my auto box later this year and might build a permanent structure, with foundations including filling the blocks with concrete. Practical considerations mean a depth of block of only 44 cm with a flat floor would be best.
Is that going to give sufficient clearance to get the box off and more importantly back on? How high is a gearbox when off the car?
varche
Marie
    • 2ltr LPG Estate
Re: Minimum pit depth for a gearbox change
« Reply #1 on: 01 March 2008, 15:10:22 »
firstly it depends on what type of box you have. when i did mine last month we used 15" axle stands which were good anything lower then this i would sugest that you wouldnt get the box out from under the car. the more space you can give yourself the better.
theolodian
  • I need a new avatar.
« Reply #2 on: 01 March 2008, 15:28:52 »
44cm between the wheels and the ground should be plenty.  At that height you will need a long floor jack or spacers that can reach high enough.
Varche
    • Golf Estate
« Reply #3 on: 01 March 2008, 16:21:26 »
Thanks, I have got plenty of stout wooden blocks.
varche
