Author Topic: Aldi £25 Jump Start  (Read 2460 times)
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
Aldi £25 Jump Start
« on: 01 March 2008, 14:36:52 »
Well, it works, had a flat battery this morning.
I like red cars
Re: Aldi £25 Jump Start
« Reply #1 on: 01 March 2008, 14:53:30 »
Always good to know  :y
Had you left anything on or is it new battery time?
Auto Addict
  • North Birmingham
    • Astra K Elite ST
« Reply #2 on: 01 March 2008, 14:57:23 »
Don't know why it went flat, apart from I've only used it 3 times this week, and then for short jouneys.
Batteries just over 2 years old.
Tested it with a meter, it was reading 11v.
Alternator is charging correctly.
Got it on charge now.
I like red cars
Bandit127
« Reply #3 on: 01 March 2008, 20:47:16 »
11V is hedgehog meets the A303 type flat.
You could drive around with no alternator charging at all for 3 short journeys in a week with a full battery. (Unless it's at night with fans, wipers etc going).
I would check your connections are nice and clean while you are charging. If not, it's time for the wire brush and vaseline.
From memory,
12.2 V is flat.
12.8 - 13.2 V is a charged battery
13.8 - 14.4 V is healthy charging from alternator.
Much above 14.4 V and the regulator in the alternator has gone and your battery is about to be toast. (My Honda VFR put out ~25V like this - the battery was indeed toast).
If you only have 13.2V with the engine running you have no charge.
Good luck.
Jim
Auto Addict
  • North Birmingham
    • Astra K Elite ST
« Reply #4 on: 02 March 2008, 07:53:39 »
From memory,
12.2 V is flat.
Good luck.
Jim
I'll double check it, thanks.
I like red cars
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
« Reply #5 on: 02 March 2008, 10:35:37 »
You been using one of those Acme solar battery chargers again AA?
TuBy's new whipping boy.
Auto Addict
  • North Birmingham
    • Astra K Elite ST
« Reply #6 on: 02 March 2008, 18:54:03 »
 ;D ;D ;D ;D
I like red cars
Auto Addict
  • North Birmingham
    • Astra K Elite ST
« Reply #7 on: 02 March 2008, 18:56:15 »
From memory,
12.2 V is flat.
Good luck.
Jim
The good news is the alternator is charging @ 14.27v. :y
This morning, the battery was reading 12.47v :(
I like red cars
« Reply #8 on: 02 March 2008, 18:58:50 »
From memory,
12.2 V is flat.
Good luck.
Jim
Thats because you have polished the battery away :o
Seriously, at least you have a TC card, and Go batteries seem to be pretty good in my experience (got one on the MV6)
Auto Addict
  • North Birmingham
    • Astra K Elite ST
« Reply #9 on: 02 March 2008, 19:09:13 »
From memory,
12.2 V is flat.
Good luck.
Jim
The original battery lasted 3 years and 1 month, just out of warranty >:(
Put a 70amp Go battery on it (thinking it might last longer), 3 years 2 months ago >:(
I like red cars
Taxi_Driver
« Reply #10 on: 02 March 2008, 20:26:20 »
From memory,
12.2 V is flat.
Good luck.
Jim
Do you get the green charge state on the battery or is it always black?
Im still on my original battery........and that gets a lot of abuse......during daylight prolly starts the omega 20/30 times/day......and during darkness.....rarely turn it off.....coz i dont want to keep turning the HID's off/on.....i know its draining the battery on idle......coz the interior light dims when the cooling fan kicks in.
« Reply #11 on: 02 March 2008, 20:30:34 »
I saw the thread title and thought.....
'well, he needs all the help he can get at his age'   :D
Then when I read it you were refering to batteries.
The trouble is that your battery actualy gets a very hard life because it never gets a good solid regular charge....
Auto Addict
  • North Birmingham
    • Astra K Elite ST
« Reply #12 on: 02 March 2008, 20:42:12 »
Yeah, I know, I should get out more :(
I like red cars
Taxi_Driver
« Reply #13 on: 02 March 2008, 20:45:43 »
I thought you (AA) and Mark had come up with a trickle charger solution for your battery.
I guess you dont use it all the time  :-/
Perhaps using it all the time (if you dont already) would solve the prob.
« Reply #14 on: 02 March 2008, 20:45:58 »
Wonder if the trickle charging isn't helping much  :-/
