Author Topic: Are these donuts for omega or Carlton?  (Read 4495 times)
« on: 13 October 2011, 02:53:45 »
Look like the right depth to be omega, but only seen solid moulded carlton ones. If they genuinely fit omega...  Hmmmm.
Anyone used these? Needles to say, we know Carlton donut bushes do "NOT" fit omega.
http://www.ebay.co.uk/itm/VAUXHALL-Omega-B-FRONT-Subframe-Bush-Rear-LH-RH-x1-/180687989044?_trksid=p3286.m7&_trkparms=algo%3DLVI%26itu%3DUCI%26otn%3D3%26po%3DLVI%26ps%3D63%26clkid%3D3436009647135213782#ht_910wt_751
Re: Are these donuts for omega or Carlton?
« Reply #1 on: 13 October 2011, 07:30:43 »
Ooh... Tempting ::)
    • E250 Est / Elroq
« Reply #2 on: 13 October 2011, 07:32:31 »
"WE USE THESE BUSHES IN OUR OWN WORKSHOP"
I wonder what for ;D ;D ;D
« Reply #3 on: 13 October 2011, 09:30:32 »
The way I read that, they go at the front of the car? Description is a tad confusing 'FRONT subframe bush - Rear LH / RH'..
« Reply #4 on: 13 October 2011, 11:11:49 »
I think they mean front of the rear subframe but it's as clear as mud.
What was the issue with Carlton bushes in the end? Offset position of the metal insert IIRC? Could be cut down on one end and a spacer used at the other worst case?
« Reply #5 on: 13 October 2011, 12:54:37 »
yeah tried that, which worked.... they are also too tight a fit, so still worked out over time. Shame, car felt good while they where seated correctly, but could feel the car get loose as they worked out, usually by about 10mill.
« Reply #6 on: 13 October 2011, 13:03:19 »
And yes, its very poorly worded. Makes you wonder if they know a Carlton (omega a) from omega (omega b) both sometimes revered to as omega. Construction/moulding looks identical to Carlton/omega a.
    • E250 Est / Elroq
« Reply #7 on: 13 October 2011, 13:07:16 »
seach on part no takes you to :
http://seekpart24.com/qh/mounting-axle-body-ems8294
which shows VX 90 447 156
    • E250 Est / Elroq
« Reply #8 on: 13 October 2011, 13:14:01 »
and that IS an omega B bush :y
« Reply #9 on: 13 October 2011, 13:32:29 »
/strokes chin
Wonder if TBE could do with some rear bushes...   ...not that I think it will help with its awful stability problems at the moment...
    • E250 Est / Elroq
« Reply #10 on: 13 October 2011, 13:39:24 »
Playing in EPC...
90447156 4 02 942BLOCK, DAMPER, REAR MOUNTING   2
  Note: EXC.AMBULANCE/ARMOURED BODY/HEARSE
I wonder what effect this would have :
 90539049 4 02 945BLOCK, DAMPER, REAR MOUNTING   2
  Note: FOR AMBULANCE/ARMOURED BODY/HEARSE
    • E250 Est / Elroq
« Reply #11 on: 13 October 2011, 13:41:34 »
* Jimbob wonders if Chris is on the phone to Vauxhall yet
Martin_1962
« Reply #12 on: 13 October 2011, 14:52:10 »
Martin thinks he has ordered them!
2woody
  • Northumberland
« Reply #13 on: 13 October 2011, 15:48:31 »
I have a pair on trial soon with filled-in voids ( polyeurethane adhesive )
« Reply #14 on: 13 October 2011, 18:35:34 »
Playing in EPC...
The seek part quoted shows quinton hazel, which has voids?
