aux input ccrt700
Started by MV6Danny, 15 October 2011, 21:25:14
MV6Danny
Hi does anybody know if you can wire an aux input to a ccrt 700 via the traffic master system if i ditch it. when i press the button to activate the traffic master the display says :aux in, so there must be an aux input built into the stereo.
If you can do this is it a small power supply that switches the stereo in to aux mode like an amp remote wire turns an amp on? If somebody knows if and how to do this it would be great if you can let me know. A wiring diagram would also be helpful. :y
Back in the MV6 again now
I_want_an_Omega
The aux input is mono  :(
Good idea though
None of the factory fit Omega radios have an aux in suitable for music
Dave DND
Quote from: TheBoy on 15 October 2011, 23:59:06
No matter how many times we all say it, nobody ever listens   ::)
Radio & Decoding Technician
www.dndservices.co.uk
MV6Danny
Quote from: Dave DND on 16 October 2011, 09:32:41
ok thanks, just thought i would ask. a tape converter it is then. :D
MV6Danny
 :D :D :D :D :D :D
I think i have found the solution to my problem and anybody else that wants an aux input for their standard head unit :y
I found this on the bay :
ISIMPLE UNIV AUX AUDIO INPUT
Only problem is the arial connecters are not the right ones but i am sure it could be modified :y
Yes, plenty of FM transmitters about....most are rubbish.
I know Dave DND sells a known very good one.
No idea on the quality of yours.
MV6Danny
Quote from: Jimbob on 20 October 2011, 07:14:41
He never mentioned that you could do it that way in his reply to this post. Might have to contact him then as i havent bought this yet and its from usa. would be interesting to see how much it will cost :y
prob got missed, its referenced in countless other posts in here.
MV6Danny
Quote from: Jimbob on 20 October 2011, 07:48:01
http://www.dndservices.co.uk/am-88t.html
is the one
That is a wireless one. The one that i was thinking of getting is wired so should get less interference. I would have thought. ???  :y
Quote from: MV6Danny on 20 October 2011, 08:12:46
is the one
The one from Dave has had some stunning reviews though ;) ;)
Dave DND
is the one
Because the Omega has an amplified built in FM aerial, any extra joints in the cable for a modulator etc will result in an even weaker signal when listening to FM, which is why they are no longer considered for use here.
Quote from: Dave DND on 20 October 2011, 08:37:40
is the one
There you go... A sensible, technical answer from someone in the know :y :y
FM adapters or cassette adapters were not offered as the question was 'Aux input on CCRT700' ;)
