Author Topic: police spec engine/car?  (Read 3278 times)
azza_126
  • bedfordshire
    • omega 3.0 v6 manual
« on: 28 October 2011, 23:19:21 »
im aware that most police cars are remaped and generally have the biggest spec brakes and best spec suspention (or even an non standard upgrade) what has been done to the omega ( 1994 early spec 3l v6) ? my car seems to act if it has a upgraded cams as it gets to about 3-4k and the just takes off and almost within a second or 2 it bouncing of the limiter (it is manual) is this normal? to me it seems like a very distinct power band which is what u get from uprated cams. also i notice that it doesnt have any cam sensors even tho the wires are there it doesnt have the pullys for it aswell just 4 of the same pullys no pick up cams with lobes. can any one help or tell me other wise
Re: police spec engine/car?
« Reply #1 on: 28 October 2011, 23:22:28 »
Very rare for any Omega to have anything done by the Police ;)
Except for heavy duty springs sometimes :-\
The "Power Band" you talk of sounds like the multiram system
birdman
  • Chepstow
  • one volunteer is better than ten pressed men
    • 03 2.2petrol gls estate
« Reply #2 on: 28 October 2011, 23:35:19 »
Guess its because you have a 3.0 V6!!!! :y ;D
« Reply #3 on: 29 October 2011, 00:52:18 »
If a V6 noticeably kicks its' heels up around 4k RPM it's normally because the multirams aren't working properly. They should pull like that from around 2.5K.
« Reply #4 on: 29 October 2011, 02:33:55 »
Agree it sounds like your multi rams are faulty...
... Only thing I suspect the plod play with is dif ratio  :-\
azza_126
  • bedfordshire
« Reply #5 on: 29 October 2011, 10:14:51 »
so how do u fix them and where r the multi rams?
« Reply #6 on: 29 October 2011, 10:25:11 »
heavy duty rear springs, beefier alternator for all the police gizmo's some have a different ratio diff, but other than that, factory standard, no remaps or brake upgrades.
This describes multi-ram operation:
http://www.omegaowners.com/forum/index.php?topic=90513.0
Ohh and leave text speak to the kids at school  ;)  :y
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #7 on: 29 October 2011, 10:44:35 »
I've had a few explod now, and some have had Re Maps Ive even found a couple with enlarged Throttle Bodies, never got down to the Cam detials. some of the ones Ive had did go like stink, where others just seemed standard, surprisingly the quicker ones had pretty much standard diff ratio.
« Reply #8 on: 29 October 2011, 11:00:59 »
Plod Omegas are pretty standard mechanically.  Its seems some forces did remap for specific uses, only one I've seen that felt like remap was a 3.0 TVP ARV (and an auto!). Whether it was mapped by old bill or subsequent owner though...
...and I tried the chip in mine, but my existing chip was quicker (although the TVP was a quicker car, presumably lighter (all ARV cabinets long removed), and possibly lower geared (doubt it was LSD on an auto))
Never, ever seen engine mods.
Bigger batteries and alternators, beefier rear springs.
« Reply #9 on: 29 October 2011, 11:12:02 »
Oh, and the DBW ones had beefier front pipes so they didn't glow quite so much...
« Reply #10 on: 29 October 2011, 11:13:27 »
Heavy duty cats? £700 each?
zirk
  • Epping Forest
« Reply #11 on: 29 October 2011, 11:22:10 »
!!! Does that mean my current 3.2 Manual is worth more as scrap?
« Reply #12 on: 29 October 2011, 11:29:58 »
I think you still only get £30 a pop for DBW cats.... ;)
zirk
  • Epping Forest
« Reply #13 on: 29 October 2011, 11:36:51 »
Yea, I know, wouldn't scrap it scrap anyway, unless I wrap it, a very quick remap 3.2, LPG and full stainless which for once actually softly suits the V6 engine noise rather than sounding like a Essex pimp.
azza_126
  • bedfordshire
« Reply #14 on: 29 October 2011, 14:52:33 »
the only thing thant make me think its had cams is the fact it doesnt have any cam sensors or pick ups even tho the wires are there and the covers are shaped to hold them but its got 4 of the same cam pullys is that normal?
