Author Topic: only getting heat on the passenger side not the drivers side ?  (Read 2534 times)
thomasbiglad
  • mallow co cork rep ire
    • omega 2.2
hi all im Tom ive just joined the site and have to say what  great site for knowledge and experience !
i ve done a few things already to my baby eg 2001 opel omega 2.2 16v manual 167.000 miles and going strong !
1st i replaced the thermostat [ with help from here ]
2nd i fixed the drivers electric seat [ with post on here ]
3rd sorted the petrol tank sender , it was slightly broken but was able to repair it ! [ again post on here ]
4th i flushed and changed the coolant/ did a full service eg spark plugs,oil, air filter , [ helpful hints on here ]
5th i changed the dash panel bulbs in the instrument pannel [ thanks to the mantiance section !
6th sorted a few rattles from the drivers and passenger front doors [ again maintanice section ]
BUT !! now im stuck on my final problem !
im getting no heat on the drivers side vents yet blasting really good heat from the passenger side ,
and its not just the vents you can control on the dash there is no heat on top for the front window on the drivers side , but good heat on the passengers side , and the same ffrom the foot wells , passenger side perfect and drivers side freezing !
ive checked the passenger and drivers side foot wells for leaks [ none ] and im not loosing any water eg temp is steady at 85 c and fans kick in around 91-94 c and temp returns to 85 c on gauge when driving normal or hard ! after fans , even in traffic ,
ive flushed the matrix [ from post on here ] and still the same ,
i think the cluch has been changed recent and something to do with the pedals as the under cover below the fuse housing has been disturbed , so is it possible someone has done something down ther to cause this problem ?
its geing cold now this time of year and i have to wear a jacket when driving as even when i close the drivers side vents its cold [on the drivers side
please if anyone can help it would be great as im totally stumped and dont want to go poking if i dont know what im looking for if ya know what i mean thanks .
hope to hear from someone soon !! [ ive a few days off so want to try and get it sorted ]
Tom  :)
thomasbiglad
    • omega 2.2
Re: only getting heat on the passenger side not the drivers side ?
« Reply #1 on: 07 November 2011, 18:11:35 »
quick note i forgot to say is i have the digital controls not the manual controls !
« Reply #2 on: 07 November 2011, 18:17:35 »
Have a read of this Tom. For passenger side but same controls on driver`s
http://www.omegaowners.com/forum/index.php?topic=90575.0
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #3 on: 07 November 2011, 18:20:11 »
another quality guide rob  :y
RIP Paul Lovejoy
thomasbiglad
    • omega 2.2
« Reply #4 on: 07 November 2011, 23:56:19 »
thanks rob ill check it out tomorrow and see if i can do it , hopefully it will cure it! quck note what is the proper running temp for the 2.2 just curious as i want to make sure its working properly
« Reply #5 on: 08 November 2011, 08:37:45 »
85-87
thomasbiglad
    • omega 2.2
« Reply #6 on: 20 November 2011, 16:27:16 »
sorted it , was easy enough to do , didnt have to lie underneath or head in the footwell just pulled the seat back and and opened the dooer nealt on the ground and was easy to get to , but i found it eaiser top remove the motor all together to reconnect the arm at the back so might post the tip ,
 thanks for the help guys !
markh1
  • surrey
« Reply #7 on: 28 December 2012, 16:47:25 »
I have no heat on the passenger side but the motor arm is in place, it appears the motor is not working. Is there a fuse or anything specific I should check?
Thanks,
'98 Omega 3.0 Elite Manual - Slowly having most of running gear replaced
'98 TVR Cerbera 4.5 - completely rebuilt on new chassis
Page created in 0.026 seconds with 16 queries.
