Author Topic: 2 Problems on my Omega, annoying! Aaarrgghhhhhhhh  (Read 3690 times)
Wayne
« on: 12 November 2011, 20:51:20 »
Hi chaps, long time no speak  ::)
my 2 front electric windows are making an horrendous squeaking noise when you open and close them, sort of like that annoying screeching running your fingers down the blackboard type sound  >:(
any ideas how to stop this irritating noise?
2nd problem is my car key, i only have one!
it sometimes doesn't work when i press to open or lock it, and i have changed the battery 3 times in the last month and it makes hardly any difference..
is there somewhere i can take it to be fixed, and how do i get a spare key made WITHOUT paying Vauxhall hundreds of ££££?
thanks very much
Michael2.6
  • Bishop Auckland
    • Vauxhall Omega
Re: 2 Problems on my Omega, annoying! Aaarrgghhhhhhhh
« Reply #1 on: 12 November 2011, 21:27:08 »
try WD40 on all moving parts when door panel is removed
this is your first port of call
there are lots of keys on ebay but needs tech 2 to code the new key to your car
noel
  • frome somerset
  • i feel the need for speed
    • 02 omega 2.6 v6 cdx auto
« Reply #2 on: 12 November 2011, 21:29:45 »
try a bit of wd40 on the rubbers that the windows run up and down in it may help :y
fiend61
  • york
  • each to their own
    • 2.5cdx 3.0mv6 3.2vec c
« Reply #3 on: 12 November 2011, 21:56:38 »
personally i wouldnt use wd40  ???
french chalk will work and less messy  :y
also key pcb sounds cream crackered  :(  guy on here martin imber is a wizard at repairing them  :y
markspark
  • Bolton
« Reply #4 on: 12 November 2011, 21:57:18 »
i always use Mr Sheen on my window runners works really well
if your keys starts the car fine then its only the fob you need maybe the butons are fubared try martin imber (think thats correct) on here he fixes the fobs
fiend61
  • york
  • each to their own
« Reply #5 on: 12 November 2011, 22:02:24 »
get another key cut and take out the transponder inside your old one and put in new one then send old one to martin. the new key with the transponder will open the car manually and start the car  :y
untill you get your repaired one back then swap the transponder back and have your central locking working off the key again  :y  plus at least you will have a spare key in future  :y
dad1uk
  • Birmingham
    • Vauxhall Zafira 2.2
« Reply #6 on: 12 November 2011, 22:10:13 »
Fiend beet me to it ;D
It's probably a loose connection in the fob - Martin should be able to sort it :y
best wishes
Simon.
car-nut
  • Kent Border, East Sussex
  • Me & My Motors are Truly 1 off's
    • Custom Mondeo TDCi Estate
« Reply #7 on: 12 November 2011, 23:36:35 »
The best thing in my opinion for the window squeeking long term is Sylicone Spray. After squirting just one time on all the cars I have had that problem with in the past it stopped it up until after I got rid of the cars.
As for the key, I would recommend either using Martin Imber or my local main dealer Vauxhall quoted me £40 programmed for just the remote part for a 3 button remote for my Omega. or if I wanted a complete key with programmed chip for immob providing you have the code with the history on a credit sized card my local dealer would do it all for £80.
« Reply #8 on: 13 November 2011, 10:36:03 »
I use silicone spray as well - the stuff for nylon curtain rails.  That hardware store on Holloway, just off Cowley Rd, should sell it.
Fob - iirc, yours is an estate, so 2 button? If so, just resolder the battery holder, as one of the connections would have broken ;)
« Reply #9 on: 13 November 2011, 10:38:04 »
As for replacement keys:
Blade and transponder - £10ish, egay
Getting key cut - fiver? Expensive, as it is Oxford ;D
Fob - £25 - £40 depending on type, dealer
Tech2 - £10 - http://theboy.omegaowners.com
« Reply #10 on: 13 November 2011, 13:16:22 »
Dont get silicone on the glass though, nightmare to remove.
PTFE spray works better imho :y
fiend61
  • york
  • each to their own
« Reply #11 on: 13 November 2011, 14:29:41 »
does that mean it started again as soon as you got rid of the cars  ;D ;D ;D
big mel
  • Oldham Lancs
  • ex trucker' GB. USA. CONTINENT& GB
    • Omega 2ltr gls 2000frpp
    • big melL
« Reply #12 on: 13 November 2011, 16:32:23 »
where can you buy ptfe spray? mel.
THE TRUCKERS MOTTO. keep the shiny side up & the greasy side down. the bugs off your glass &  the bears off your ass.
Wayne
« Reply #14 on: 13 November 2011, 18:34:59 »
COOL!!  ok, i`ll message Martin to do it for me i reckons
or, i can take my existing damaged key to Vauxhall and get a brand new key fob that does central locking and immobiliser and starts the car for about £80 ?
